stroker
stroker Reader
3/23/10 10:49 a.m.
Assume repair/modification of an aluminum sportbike frame (in this case a 1989 GSXR750). What standard aluminum alloys will be most appropriate?
44Dwarf
44Dwarf HalfDork
3/23/10 3:37 p.m.
6061 i think but not 100% positive Look up "old school gixer" or something like that i lost my bookmarks.
I've got a few engine parts kicking around if needed.
96DXCivic
96DXCivic Dork
3/23/10 9:38 p.m.
I would assume 6061 and Pray to god it isn't 7075.
eebasist
eebasist New Reader
4/3/10 8:07 p.m.
What do you mean by repair/modification? You do know that the frames are heat treated after welding in order to releave stress and build strength correct? If this is a structural piece I would be carefull
stroker
stroker Reader
4/3/10 10:25 p.m.
I have a project that will require extending the frame to fit a physically larger engine. That will require inserting plugs to the frame tubes OR welding two frames together. That's what I mean.
Yes, I know the frames are stress-relieved.
qByMXN1lZcMMn7tJL4vRdOyh9o0GngoBauT2ToTuYvLjSOvpq2AxvleX90qPvLTm
