EvanB
EvanB SuperDork
3/23/11 10:42 a.m.
I bought a Suzuki GT250 last fall and haven't done anything with it yet. Last night after work I decided that instead of sitting around watching TV I am going to turn it into a Cafe racer of sorts.
After one night I have a lot of parts stripped off, including the forks out to replace the seals and clean them up a bit.
The plan is to strip off everything unnecessary (which isn't much), mount a small AGM battery and electronics under the seat and build a new wiring harness for it. Along with cleaning everything up and repainting where necessary.
Pictures to come.
flountown
flountown Reader
3/23/11 10:48 a.m.
Why would you tease us and not lead off with pictures...not cool...
EvanB
EvanB SuperDork
3/23/11 10:57 a.m.
Here are a couple pics of what it looked like before I tore into it.
EvanB
EvanB SuperDork
3/23/11 10:58 a.m.
Oh yea, also planning on rearsets, clubman or clip-on bars, and removing the side covers and finding a smaller oil tank to hide somewhere.
flountown
flountown Reader
3/23/11 11:17 a.m.
EvanB wrote: Oh yea, also planning on rearsets, clubman or clip-on bars, and removing the side covers and finding a smaller oil tank to hide somewhere.
If you are doing a standard tail piece for the cafe, perhaps turn it into a tank.
93EXCivic
93EXCivic SuperDork
3/23/11 2:36 p.m.
Nice. I want an old two stroke like that.
MitchellC
MitchellC Dork
3/23/11 5:28 p.m.
Or plug the oil lines and run premix.
93EXCivic
93EXCivic SuperDork
3/23/11 6:36 p.m.
The oil tank on my Yamaha is a bit smaller then that one. But probably not small enough to really hide.
EvanB
EvanB SuperDork
3/23/11 6:54 p.m.
The oil on these gets injected directly to the bottom end so they are happier with the injection.
Curmudgeon
Curmudgeon SuperDork
3/23/11 6:59 p.m.
Cool! Keep us posted on your progress.
If it doesn't already have them, reed valves give a big power boost. Throw on a pair of expansion chambers and it should scoot pretty good. Jemco can make about any kind of pipe you want but they are pricey. DIY is possible also: a long time back a buddy and I cut the original head pipe off of his 185 Suzuki and spliced on the rear section of a Hooker expansion chamber from a trashed 175 Yamaha. I'm sure the purist pipe builders are cringing right now, but it worked great!
EvanB
EvanB SuperDork
3/23/11 7:05 p.m.
Some horrible cell phone shots of the teardown so far. Not a whole lot to see.
EvanB
EvanB SuperDork
3/23/11 7:07 p.m.
Curmudgeon wrote: Cool! Keep us posted on your progress. If it doesn't already have them, reed valves give a big power boost. Throw on a pair of expansion chambers and it should scoot pretty good. Jemco can make about any kind of pipe you want but they are pricey. DIY is possible also: a long time back a buddy and I cut the original head pipe off of his 185 Suzuki and spliced on the rear section of a Hooker expansion chamber from a trashed 175 Yamaha. I'm sure the purist pipe builders are cringing right now, but it worked great!
It doesn't have reed valves, I would like some but that requires much more skill than I possess. I plan to keep the engine pretty stock for now. Maybe some expansion chambers, larger carbs, and porting in the future.
stuart in mn
stuart in mn SuperDork
3/23/11 7:56 p.m.
The GT250 was actually a pretty fast bike in its day, at least for the 250 class. It's a direct descendant of the X-6 Hustler, with the Ram Air scoop grafted on top of the head in an attempt to keep the pistons from seizing under hard use.
Curmudgeon
3/23/11 8:11 p.m.
X-6 Hustler. I wanted one just because of the name.
EvanB
EvanB SuperDork
3/23/11 8:28 p.m.
This was my previous GT250, it was all stock and quite fun.
http://www.youtube.com/watch?v=COl9xgGs1Aw
fasted58
fasted58 Reader
3/23/11 8:34 p.m.
Love those old two strokes, had a RD 350 for street and a GT-750 in a DSR.
mo4gxMwrrDeCPlpO3VWVsO34Zwktp2GjRkLbI0MQMCY5tFgLgwUhri7b1pofaHau
