Grtechguy
Grtechguy SuperDork
4/26/11 11:31 a.m.
Is the only difference between the 883 and the 1200, the pistons and cylinders?
http://lansing.craigslist.org/mcy/2346852665.html said: BRAND NEW IN THE BOX V-TWIN EVOLUTION SPORTSTER 883-1200 COVERSION KIT These kits feature Wiseco forged pistons and rings, and V-TWIN cylinders and gaskets. They fit Harley Evolution® 883 Sportster® models from 2004 thru 2010, This kit does not require any head work to be done. NO MACHINING REQ. Yields 10:1 compression ratio These are the top quality kit not to be fooled with the cheaper made versions of this kit VT11-0337 black finish (silver edges on fins) Bought Brand new and never installed. Also have brand new Vance and Hines Blackout 2 into 1 Pipe for this bike that has never been installed. can add on for $400$
BoxheadTim
BoxheadTim SuperDork
4/26/11 11:33 a.m.
I'm not Dr Hess but IIRC that's correct as far as the conversion kits go.
RealMiniDriver
RealMiniDriver Dork
4/26/11 12:18 p.m.
I'm not Hess, either, but that's what I've been told, too.
914Driver SuperDork
4/26/11 12:21 p.m.
I'm not Hess either, but my buddy has a 1200 kit that bolts right on to his 883. Bought it 13 years ago, still looking for free time.
Not Hess.
Dr. Hess
Dr. Hess SuperDork
4/26/11 2:36 p.m.
I am Hess. FOR THE MOST PART, that is the difference. There are other subtle changes, but the two engines are MOSTLY the same. Seats, accessories, etc will be different between the 2 bikes, as the 883 is sort of a "base model" and the 1200 is "fully loaded." To convert a 883 to a 1200, yeah, you just put the new pistons and cylinders on. The bottom ends are the same (same stroke, rods, etc.) Remember that a 883 is really what was called a 900. You can also bore out your existing cylinders and just put new pistons in, but the new jugs cost a few bucks more than a proper bore job, so why bother? If I recall, you don't have to bore the cases out to go to 1200, but if you want to go bigger, you may have to. I offered to convert Dr.Linda's 883 to 1200, but she said that she had enough power as it was, especially with the Megasquirt now.
Rusnak_322
Rusnak_322 HalfDork
4/26/11 3:56 p.m.
Suprised that there are not new heads or at least larger valves.
Dr. Hess
Dr. Hess SuperDork
4/26/11 3:59 p.m.
In 1987, you could get a 883 or an 1100. Later, they changed it to a 1200. The aftermarket community immediately came out with all kinds of kits to swap the pistons and jugs out with. I think you could get a 1600cc Sportster kit. You would have to bore the cases out for that.
Grtechguy
Grtechguy SuperDork
4/26/11 10:10 p.m.
Seems like a cheap upgrade.
Mental
Mental SuperDork
5/6/11 3:17 p.m.
BoxheadTim wrote: I'm not Dr Hess....
RealMiniDriver wrote: I'm not Hess either...
914Driver wrote: I'm not Hess either,...
914Driver wrote: ...Not Hess.
Dr. Hess wrote: I am Hess...
I couldn't love GRM the magazine or the website more, and believe me, I don't like to be the P.C police or anything or the guy who has a problem with everything thing, but I do have a problem with this... I find it a bit offensive that you use terms like "Hess", "Dr" etc etc... for your little descriptions or whatever in the land of cyberspace. I myself do not have a medical degree, nor am I an internet stud like Dave Hardy, but I feel sensitivity for people with student loans the equivalent of three Latin American nations, and my friend in Arkansas has a degree in the field.
These terms although I'm pretty sure are not even real words, are obviously meant to resemble the words used to describe people with a Europa and awesome bread recipes, and it appears that they are used on these boards in a joking sense which, as I view it, makes light of people who do have a medical certification. It just doesn't seem right to me, that's all. I know that it's not my message board, and that no one forces me to post here, but all the same, some things are wrong when they really don't need to be.
Dr. Hess
Dr. Hess SuperDork
5/6/11 3:32 p.m.
You're bad, doode.
Xceler8x
Xceler8x SuperDork
5/6/11 4:59 p.m.
Who's gonna tell Mental Hess is a real Doktor. As in the medical kind and not the "Doctor of Love" kind?
mpolans
mpolans New Reader
5/7/11 8:49 a.m.
Rusnak_322 wrote: Suprised that there are not new heads or at least larger valves.
IIRC, I could be wrong, but I thought the 1200 did come with bigger valves and a slightly larger combustion chamber, but the difference isn't enough to matter for most folks. Regardless, the piston and cylinder swap kits are bolt on deal
Dr. Hess
Dr. Hess SuperDork
5/7/11 9:12 a.m.
I took a quick look at my parts manual and the valves are different. Different valves and seats, different head, just by part numbers. Also, interestingly enough, the flywheels are different based on part numbers. I could look at the specs, but I'm pretty sure the stroke is the same.
Appleseed SuperDork
5/8/11 12:22 p.m.
Dr. Dre takes issue with Mental.
Mental
Mental SuperDork
5/9/11 6:37 a.m.
Xceler8x wrote: Who's gonna tell Mental Hess is a real Doktor. As in the medical kind and not the "Doctor of Love" kind?
Psssstt....I already knew that. He is also a wise sage and really does have an awesome sourdough recipie. http://www.drhess.net/
RossD
RossD SuperDork
5/10/11 4:16 p.m.
I tried making the sour dour recipe but got a 4age flywheel in there some how...I think I lost a page after printing it out...
Dr. Hess
Dr. Hess SuperDork
5/10/11 8:25 p.m.
You use the flywheel for the yeast. Duh.
carzan
carzan HalfDork
5/12/11 5:37 a.m.
Here's a picture of a canoe in a field. I don't know how long it's been there.
fasted58
fasted58 Reader
5/16/11 4:47 a.m.
preggo canoe
IPV0GaSaPQhAvYzlE89IoAUtu1RPSwfqmRRKN6WfxKLndmNmiHXrp8gJ4SEUegQr
