ditchdigger
ditchdigger Dork
12/23/11 5:26 p.m.
My father drove down from portland today with this on a trailer.
Photobucket
He bought it last year to commute to work on and after 3 days realized his knees couldn't take kick starting it. He parked it in the back of the garage and forgot about it. He thought I would actually do something with it and use it so he gave it to me.
It is a 71 CL125 scrambler
Photobucket
Photobucket
It will probably make a better commuter than the vespa.
He says it starts right up if the battery is charged, but since it is dead now I can't get anything out of it. He did add stabil to the tank before he parked it. Hopefully it won't be too gummed up.
First thing it needs is tires. I can't believe he drove this thing anywhere on these old cracked things.
Woody
Woody SuperDork
12/23/11 5:29 p.m.
That's awesome!
Hint: Everybody puts premium in the tank because it's so small. Use regular and it will start easier.
Woody
Woody SuperDork
12/23/11 5:30 p.m.
Just noticed the cable brakes. You may want to put some new cables on there.
Curmudgeon
Curmudgeon SuperDork
12/23/11 5:44 p.m.
A buddy had a CL100, he could keep right up with all the guys on the SL true dirt bikes when we got in the snotty stuff.
The cables will be goopy, get a cable luber, blow them out good with carb cleaner and then lube them. The brake shoes are bonded not riveted and yes the linings will come off! BikeBandit shows shoes for $19.55 per wheel.
Neat little bikes and nearly indestructible! Have fun.
Woody
Woody SuperDork
12/23/11 5:59 p.m.
I'd just be worried about the cables breaking or blowing out of their casings. For brakes, I'd replace them to be safe.
ditchdigger
ditchdigger Dork
12/23/11 6:40 p.m.
Due to my location and proclivities I have no intentions of ever taking this thing off road. I plan on swapping the sprockets out for the more relaxed CB units and installing some road only tires.
Other than that some bars with less rise and maintenance is about all it will get. Keep it simple, right?
wbjones
wbjones SuperDork
12/23/11 6:56 p.m.
you could box it up and send it to WNC .... though I doubt you will
Woody
Woody SuperDork
12/23/11 6:59 p.m.
The bar swap is a little trickier than you might think, since the cables and wires run inside them. They will be stiff, brittle and too long when you add a lower bar. It's easy to ruin them (and your switches) when you try to get them out after 40 years. Enjoy it as it sits.
Been there...
ransom
ransom Dork
12/23/11 8:55 p.m.
In reply to Woody:
I have never known this man to own a mechanism that he could leave completely alone.
Maybe silverware.
TRoglodyte
TRoglodyte HalfDork
12/23/11 9:08 p.m.
Looks like a commuter/trials bike from here . Ride it anywhere you don't want to walk.
Woody
Woody SuperDork
12/23/11 9:12 p.m.
ransom wrote: In reply to Woody: I have never known this man to own a mechanism that he could leave completely alone. Maybe silverware.
Fair enough. I just checked the contents of his garage and he seems well up to the task.
TRoglodyte
TRoglodyte HalfDork
12/23/11 9:17 p.m.
Make a bong out of it?
stroker
stroker HalfDork
12/23/11 10:36 p.m.
first thing you do is put some air in the rear tire.
44Dwarf
44Dwarf Dork
12/24/11 6:57 a.m.
That would be great for the 150cc and under single 4 stroke under TT and flat track class.
Woody
Woody SuperDork
12/24/11 7:21 a.m.
I love the simplicity of this thing: One cylinder, one carb, two valves and cable operated brakes.
Curmudgeon
12/24/11 7:38 a.m.
Dood. Those ARE road only tires. I wouldn't trust them on anything more challenging than dusty asphalt. Caution: it is VERY easy to cross thread the valve adjuster caps! BTDT.
The_Jed
The_Jed Reader
12/24/11 9:21 a.m.
Nice bike!
If you swap out the handlebars and want to sell the originals the wife is looking for a set similar to those for her XS400.
Woody
Woody SuperDork
12/24/11 9:28 a.m.
If that has a cam chain tension adjuster, be very careful if you try to adjust it.
Curmudgeon
12/24/11 9:40 a.m.
Yeah, that should be the one with the eccentric bolt setup that bows the tensioner. IIRC the eccentric's at the bottom, behind the left side magneto cover. You'll also find the oil strainer down there, behind another one of those caps like the valve adjusters have. The strainer is spring loaded. It has a centrifugal oil filter on the end of the crank on the right side, also. EDIT: I had a brain fart. The tensioner's down there but it's not the eccentric type.
Woody
Woody SuperDork
12/24/11 9:42 a.m.
That bolt will strip in a heartbeat
ditchdigger
ditchdigger Dork
12/24/11 9:49 p.m.
The battery is less than a year old but seems to be dead. With the charger on I can start it first kick. After 6 hours of charging it still won't fire up without the charger running.
I don't have the manual for this yet but shouldn't the stator or coil give enough poop to make it run? Is the bad battery too much of a load on the system so it can't generate spark?
Other news the muffler is pretty shot. Dime sized holes on the bottom and it sounds awful. Needs for fork oil and seals too.
Curmudgeon
12/24/11 10:01 p.m.
Those are battery and coil ignition. No battery = no spark. There are rectifier kits called 'battery eliminators' as a way around that, but they won't run the lights. Or you can use a RC car battery pack.
JoeyM
JoeyM SuperDork
12/24/11 10:04 p.m.
ditchdigger wrote: My father drove down from portland today with this on a trailer. Photobucket
You could do this
fast_eddie_72
fast_eddie_72 SuperDork
12/24/11 11:34 p.m.
I really, really like that. I've always been too chicken to ride a bike, but if I did, it would be something old, cool and small like that. Just super cool.
ditchdigger
ditchdigger Dork
12/25/11 12:03 a.m.
In reply to Curmudgeon:
Thank you sir. Just what I needed to know.
X7XCxcQN9DCDolNF19lUy8ju8xeSh9D1F3hhAuiM1sDRYbjJHJZfQu72XLgR2KAv
