foxtrapper
foxtrapper PowerDork
4/6/14 7:03 p.m.
Finally decided to go up the spot I crashed last year. With the GPS I had on the bike at the time, I was able to pinpoint the spot on the ride it happened. I'd been kinda putting it off. But, it's pre-spring, so everything is very clear and observeable. Took the boy and we found it.
Wish I could say it was something impressive or a really difficult spot. It wasn't. A little tough, but nothing remarkable. Probably an optional choice on that trail ride. It's a crash that should have been nothing more than of "Uf" when I landed, and continue to ride.
The section of trail is quite rocky, with loose sharp edged rocks anywhere from baseball to backpack sized. Moderately steep downhill, but nothing terrible. You're in a ravine, so there's really no getting out. Walking down it was a little tough as the rocks would roll out from under your feet. I think I do remember that. From a motorcycle perspective, the worse things were the small logs diagonally across the trail to control erosion. One of those is what got me.
My son and I spent a little time looking it over, even figured out where it had happened. It wasn't until I started from further up and pretended to ride down that it all made sense and came together. As soon as I started pretending to ride, I could easily replicate it all.
I was going slow, picking my way through the rocks(GPS showed ~7-8 mph). As I would come to a log I would have squared to it, bumped the tire over the logs (they were only about 10"), and squirted the rear over. I almost remember something about disliking all the rocks, and thinking this was not fun.
On one log, there were two possible lines. We think I took the right hand line. That would have been the squarest. But that line would have me with my front tire right up to a stump and rock once I cleared the log. So I would have turned to the left as I brought my rear tire over.
And that's what did me in. Doubly so since I think it was a wet that morning from rain the previous night.
The rear tire squirted to the right, and it dumped me hard to the left. That section of the log is damaged, like a spinning sliding rear tire tore it sideways. You could see where there is a chip on one of the rocks holding the log in place, right where my clutch lever would have hit, explaining why it was shoved up the handlebar. The log is gouged a few inches from that chip, right where my handlebar would have it, which would explain the wood that was stuffed into my handlebar end. There's even a funny rock with a double barb that matched the strange scrape on my little windshield.
And a nice flat rock to slam into face first, which is apparently what I did. I would also have slammed onto the log on my left side, which would explain the hurt/broken ribs and partially collapsed lung. The right hand handlebar would have slammed onto my right side, matching the one fractured rib on that side.
Time line on the GPS track has me not moving for about 20 minutes. That would be likely as I sure got the wind knocked out of me. Sitting there against a tree that I likely would have sat against I got a slight flash of an image of someone else coming down the trail, almost like a faint memory.
I rode for another quarter mile, finishing the trail. The trail ended by curving as it dumped you out onto a dirt road. I would have been in very bad shape by this point (had a flash of a memory walking down this section where I knew I was in trouble, very silvery flash memory). I likely didn't even know I was on a road at first. Looks like this would have been a reconnection to the regular route. When I saw other riders, I likely stopped. Nothing special about the final stopping point. That's where the bike sat for several hours, and likely where the first ambulance picked me up.
So, simple slip of the rear tire on a log, and a hard fall over to the left. Nothing more. No great story of daring or exciting drama. Just a slip on a log and fall to the left.
I don't know how to end this. I feel like I should post some great observation or insight into my riding skills or such. I've none. I'm new to dirt, but not to bikes. The trail was challenging but far from truly difficult. I don't think I was in over my head, but maybe I was. I wasn't feeling good that day, and almost didn't ride because of it. Hell, I don't know. It just happened. Life happens.
So, I continue to recover, and continue to ride. I am a little gun shy now of the dirt bike, and dirt biking in general. Maybe something like an old Honda CT70 would be better now. I enjoy the Harley and riding that. Truthfully, banging my way through the woods isn't nearly the fun I thought it would be.
So, ride on all! Life is short, enjoy it to the max. Slide in at the end, well worn and grinning.
EastCoastMojo
EastCoastMojo Mod Squad
4/6/14 7:20 p.m.
Visiting a site where you have crashed can be a very difficult thing, and I am glad you did it so you could get some slivers of memory back on that day's events. Analyzing what went wrong and why can stir up a lot of emotions, none of which are easy ones to deal with. I'm proud of you Foxtrapper, you're definitely stronger for what you've been through. I hope you chiseled your initials in that damn rock.
Zomby Woof
Zomby Woof PowerDork
4/6/14 7:40 p.m.
That's the observation.
We take things for granted, but in a fraction of a second that can change. Mine was a routine, relatively slow speed event that has happened to me 100 times or more. When you have hobbies like this you have to always be aware of the consequences. I was two years off the motocross track after mine, but have since returned and ridden better than ever, and safer.
You just never know.
dculberson
dculberson UltraDork
4/7/14 8:33 a.m.
Good job figuring out all those details though. I can't believe you were able to keep riding with a collapsed lung and broken rib, that's impressive.. Good luck on your continued recovery.
TRoglodyte
TRoglodyte Dork
4/7/14 12:18 p.m.
You have certainly come a long way from your "Dear Diary" post. The healing process has been kind to you. As an observation there are parallels to Michael Schumachers current situation, how something so simple can go so terribly wrong in a flash.
foxtrapper
4/8/14 8:05 a.m.
Thanks for the kind words. Happened to do some web searching today about that fateful ride, learned a few things.
I was no iron man. I didn't ride down to the road, I was carried. http://www.damnriders.org/viewtopic.php?f=3&t=2981&start=30 "Gene and I came upon a downed rider who had a fairly serious concussion and rib injury. Let's just say I'm glad he was a smaller guy, cuz carrying him on the backboard down the trail would have really sucked if someone Gene's size was on it."
I thought I remembered the day being grey and damp. That's a false memory from looking at pictures of the 2012 ride. I remember these images, which are not mine. http://www.advrider.com/forums/showthread.php?t=714375&page=3
The day was actually quite nice apparently. http://f650.com/forum/showthread.php?29639-2013-Michaux-Dual-Sport-Ride.
I see the ride will be happening again this year. http://www.angelfire.com/michauxoffroadenthusiasts/images/Dualsport14flier.pdf Part of me wants to try it. Mostly from a refusing to be defeated, "tough guy", and getting back on the horse that threw you perspective or perspectives. Honestly, a larger portion of me than I care to admit doesn't want any part of it.
alex
alex UberDork
4/10/14 11:55 p.m.
How surreal it must be to read about your own injury that you have no memory of. And then to revisit the site of the crash and have all sorts of memories - some of them false! - come flooding back. And add to that all the weird stuff you went through in the early days of your recovery. The human brain is a supremely fascinating and perplexing thing. I'm glad yours is getting better.
tuna55
tuna55 PowerDork
4/11/14 7:12 a.m.
All I would concentrate on is the quality of your writing since you first told us about your accident. You've made a great recovery. You're still recovering. No need to overthink it, just visit again in a few months to see if anything else pops up.
7Y7IBwTgwTxyjVtD92ojk35Hi4HIwlw1XdW3YqMzVvroGqeR2HBB5plwN6VgAxVJ
