Dootz
Dootz New Reader
11/29/18 5:49 p.m.
So a heater return hose cannot plug back in to where it's supposed to be because the plastic pipe it was plugged onto broke and exploded coolant everywhere. What part is this plastic pipe a part of so that I can replace it?
https://i.imgur.com/zk2CLej.jpg
enginenerd
enginenerd Reader
11/29/18 6:59 p.m.
Been a while since I've looked at one of these in stock form. Not sure which variant yours is but I want to say it's part of the intake manifold assembly. You can see a similar port on the top right of this image:
Dootz
Dootz New Reader
11/29/18 10:07 p.m.
Crap. Gotta replace the whole thing (apparently it's common for that plastic pipe to crack and break off)
Stuck between the Dorman and FRPP variants for replacement...
Dootz
Dootz New Reader
11/30/18 5:51 p.m.
Thanks for the help.
I'm also wondering if you happen to know of an overdrive connection diagram? Seems like the wiring for my shifter is messed up
dj06482
dj06482 SuperDork
11/30/18 8:23 p.m.
I went with FRPP for the replacement, but the Dorman one is a lot cheaper. Supposedly you may lose a few HP with the Dorman one.
Dootz
Dootz New Reader
12/1/18 12:54 a.m.
Well, my dad went out and bought a supposed FRPP part but there's an issue - perhaps as an expert, you can explain why said broken section is blocked and/or missing:
https://i.imgur.com/eeiy3WR.jpg
https://i.imgur.com/Qq9t6WG.jpg
Part number:
https://i.imgur.com/tZ0zt7W.jpg
bpf3wgx2g3s0cTCPKn7hS2SkuVa6iztAovTzpcLv1KObjzxpBbqzfa2hEGku2xAu
