Kenny_McCormic
Kenny_McCormic UberDork
7/3/14 5:42 p.m.
Put a hammer bit in your air chisel, set it to a pretty low setting( I think I was on 1 or 2 on a CP714 with 120psi to it, you don't want enough force to damage the underlying metal), put on ear protection and rattle away, the hammering breaks the adhesive loose and it peels right up in big chunks.
Swank Force One
Swank Force One MegaDork
7/3/14 6:05 p.m.
Sounds cheaper than the dry ice method as well.
Which... does work quite well. And you can still play with a hammer.
oldeskewltoy
oldeskewltoy SuperDork
7/3/14 6:17 p.m.
Swank Force One wrote:
that can't be good for the bearings.......
Woody
Woody MegaDork
7/3/14 6:43 p.m.
Maybe that was the hammer...
Kenny_McCormic
7/3/14 10:47 p.m.
It comes up in much bigger chunks with the air hammer smacking it at room temp, like hand sized. Plus you dont have to swing a hammer, screw with chisels, etc. Discovered this trick on accident using the air hammer to form patches for my rusted out spare tire well on my prizm.
DaveEstey
DaveEstey UberDork
7/14/14 12:36 p.m.
I used cold for most of mine, but a 2" chisel bit in the air hammer at 10psi knocked out the rest pretty well. Peels it right up.
Giant Purple Snorklewacker
7/14/14 12:44 p.m.
I use a putty knife and heat gun with just enough heat to peel but not melt it.
I can do a whole E36 M3 in half an hour but, man, the first time I did it... before I got the finesse of "just enough" heat I struggled for hours.
The residue/adhesive that won't come off? Mineral spirits and a rag and it's ready for paint.
jddeadfuelpumps
jddeadfuelpumps New Reader
9/21/14 1:54 p.m.
A long time ago, I did the trunk and back seat of an e30 with a hammer and chisel. Hard work. Hard, dumb, work. All good info above.
bgkast
bgkast UltraDork
9/21/14 4:59 p.m.
Giant Purple Snorklewacker wrote: I can do a whole E36 M3 in half an hour
I think you need more fiber in your diet.
c5racer
c5racer None
4/12/15 12:24 p.m.
If you have access to liquid nitrogen, a splash is all you need. The whole chunk pops clean off. Did an RX7 with 5 gallons.
oldeskewltoy
4/12/15 7:06 p.m.
c5racer wrote: If you have access to liquid nitrogen, a splash is all you need. The whole chunk pops clean off. Did an RX7 with 5 gallons.
Brett_Murphy
Brett_Murphy UberDork
4/21/15 1:08 p.m.
Would a temperature change that drastic mess with the steel?
grafmiata
grafmiata SuperDork
4/21/15 8:21 p.m.
In reply to Brett_Murphy:
With the steel itself, maybe not.
But I would be worried about all the spot-welds and any sealers used while assembling the BIW.
gohero
gohero New Reader
4/28/15 8:20 p.m.
I have tried dry ice, but I find it still hard to remove it... So used an air chisel to remove it faster.
c5racer
c5racer New Reader
1/11/25 4:11 p.m.
In reply to Brett_Murphy :
So beating the sheet metal with a hammer and chisel seems less damaging? This is a secret method, maybe your mad I let the cat out of the bag! cheeky
CLr6QZtaUjkWtj2U6eyvKg87NCL2HHWqtMTRM9AvJyFQUQQAQ6m64yMiYKvCSfjk
