Sipman
Sipman
4/13/14 9:53 p.m.
Hi all, What I mean is assuming you get the matching diameter, are the calipers universal between from-the-auto-manufacture supplied ones and what you buy from brembo? When you go to brembo's site, they show kits with calipers, pads, rotors, and mounting adapters. My bmw comes with floating rotors, but also sliding calipers. I think they sell their upgrade kit for lots of $$$$$. If I could purchase calipers from ebay that were taken off a Porsche, or some other wrecked car, would they mate up with bmw's adapters or would brembo sell the adapter from their kit? I'd love to go fixed/multi-piston
RexSeven
RexSeven UberDork
4/21/14 5:00 a.m.
Moderator's Note: Topic moved from Tech Tips to GRM main forum for better visibility and to better fit the topic. Let's see if we can get some answers from the hive mind!
bludroptop
bludroptop SuperDork
4/21/14 5:22 a.m.
ddavidv
ddavidv PowerDork
4/21/14 5:27 a.m.
Wow, canoe within a thread itself. That's new.
noddaz
noddaz Dork
4/21/14 6:35 a.m.
Interesting. (Not the canoes) I have a pair of Brembo calipers off an Acura TL at home...
Opti
Opti New Reader
4/24/14 10:54 p.m.
I believe for the most part they are universal as in Brembo will use the same caliper for many fitments, but they do manufacture a bunch of diff calipers.
When the 1st gen CTS-V caliper swap became popular for the Fbody guy, it was found that they were a brembo caliper, and that they were used on many different fitments may times just painted differently. I believe one of the other fitments was a Evo of some sort and I remember reading about a few other fitments the calipers were used on.
kanaric
kanaric HalfDork
4/25/14 3:04 a.m.
I know Evo calipers are used on a wide variety of cars. In fact there is a site that sells it as a "brake kit" with all the hardware you need for a vairety of Nissans for example.
http://www.ao-ps.com/brakes.php
wbjones
wbjones UltimaDork
4/25/14 5:43 a.m.
ddavidv wrote: Wow, canoe within a thread itself. That's new.
we get those on a regular bases … just report them and they will quietly disappear
Sky_Render
Sky_Render Dork
4/25/14 8:37 a.m.
Pads are often interchangeable between calipers of the same number of pistons. The calipers do not.
My 4-pot Brembos are OEM Ford pieces from a GT500/BOSS. They directly bolt to my stock factory hardware and lines. There's no way in heck they'd directly bot up to a civic.
Or am I misunderstanding the question here?
z31maniac
z31maniac UltimaDork
4/25/14 8:48 a.m.
Sky_Render wrote: Pads are often interchangeable between calipers of the same number of pistons. The calipers do not. My 4-pot Brembos are OEM Ford pieces from a GT500/BOSS. They directly bolt to my stock factory hardware and lines. There's no way in heck they'd directly bot up to a civic. Or am I misunderstanding the question here?
I think so.
He's asking if the Brembo's on the BOSS, for instance, are the same as what comes on the EVO or the STi (this is what I got from it at least).
I'm sure the answer is no.
Martinator
Martinator New Reader
4/25/14 8:56 a.m.
There's a brembo 4 piston caliper from the 840ci that bolts right up to e34 5 series, e30 m3(5 lug), e32, e24, e28. Have them on '95 540; they work well and there is a good selection of Hawk pads.
SlickDizzy
SlickDizzy PowerDork
4/25/14 9:14 a.m.
I think he's asking if all of the calipers are the same but with marque-specific caliper brackets, or if the calipers themselves are different. I'd be interested to know myself.
z31maniac
4/25/14 9:21 a.m.
I'm betting no just based on different piston sizes alone.
Sky_Render
Sky_Render Dork
4/25/14 11:33 a.m.
I know a lot of the pads are the same. However, there is no way in heck the Brembos on my Mustang will swap with the Brembos on a Subaru.
Gearheadotaku
Gearheadotaku PowerDork
4/25/14 11:48 a.m.
I'll venture that some calipers may fit more than one car, but certainly not "one size fits all". The Brembos on a Range Rover are HUGE.
NMKQcmwZz4RLaMTK6YtTdaeBhfaptAawB49RymQXHNn2e8kUqikuzsAJhFgRdNpC
