SVreX
SVreX MegaDork
9/22/14 10:54 a.m.
I do this all the time, because I always have a ruler, and rarely have a compass...
Mark the center of the circle.
Divide the diameter in half.
So, for example, let's say I want a 6 1/2" circle. Half of that is 3 1/4".
Hold ruler so the radius dimension (3 1/4") is on the center mark.
Now, mark both zero and 6 1/2".
Rotate the ruler a bit, and do it again. And again. And again. It makes no difference how many times you do it, or how evenly spaced your marks are.
Connect the dots.
trucke
trucke HalfDork
9/22/14 1:15 p.m.
Or you could use a string to tie a pencil to a nail. Place nail in center of circle and rotate pencil around. Be sure to place string near point of pencil.
SVreX
SVreX MegaDork
9/22/14 2:23 p.m.
Yeah, the only problem with the string is it's a little harder to get an exact dimension. Gotta tie the knots just right.
fasted58
fasted58 PowerDork
9/22/14 2:33 p.m.
I've used a thin strip of metal in a bind, furnace tin or flashing. Punch hole at center and another at radius, use scribe or marker to outline the circumference.
Gearheadotaku
Gearheadotaku PowerDork
9/23/14 1:11 p.m.
Now that it's marked, the next hard part is cutting it nice and round....
James_S
James_S New Reader
10/1/14 7:26 a.m.
Or put a glass upside down or a plate - depends on what size of a circle you want to have ;)
Jerry From LA
Jerry From LA Dork
10/7/14 1:57 p.m.
Plumber's tape works well as a semi-rigid, accurate dimensional medium instead of the string. It's also got regular holes in it for your pencil.
trucke
trucke HalfDork
10/7/14 4:03 p.m.
I used a lid from a five gallon bucket to cut out a circle of cardboard. Placed it into the backside of my wheels when I painted them to keep paint off the back plate.
Q4JtQy8Ft5xnMNoQ7cg8Tkdi5VkMvlLCYREYDlDakmCK6HFl2w6vAPoHGg26Y2TJ
