TeamEvil
TeamEvil Dork
10/14/15 2:13 p.m.
Is there any way to remove cheap chrome plating from aluminum valve covers? Maybe an acid dip or blasting with Black Beauty? Not sure/don't know.
The plating is flaking off, but the aluminum beneath is nice.
Thanks!
RXBeetle
RXBeetle Reader
10/20/15 3:49 p.m.
I would not recommend acid. I tried muratic acid on a cheap VW steel bumper years ago and it did nothing to the chrome. I don't actually know why I thought it would in hind sight... I just let it sit longer thinking it might just help make mechanical stripping easier. Eventually I realized there was almost no bumper left, just the chrome shell... Aluminum disappears pretty quick in any strong acid so I would expect your results to be even worse than mine. Can you do something to encourage the flaking but not eat into the aluminum too deep? Salt bath for some corrosion to creep under the chrome?
erohslc
erohslc Dork
10/20/15 5:05 p.m.
Needle nose pliers, grab a loose end and pull, peel off the chrome.
erohslc
erohslc Dork
10/30/15 4:27 p.m.
On this thread, someone mentioned using 'Metal Rescue', and that it removed all the chrome:
http://grassrootsmotorsports.com/forum/grm/evapo-rust-just-saved-me-120/100540/page1/
HTH
TeamEvil
TeamEvil Dork
10/30/15 7:24 p.m.
Thanks for that link ! !
g4mQP6hT4TL496LI7hXVXMZuparlSVgtbHh81FKc32xBUXtrmmPRHB6mVs4kKzu8
