noddaz
UltraDork
11/30/20 7:18 a.m.
Is there an easy way to cut protective foam into shapes to arrange or protect things?
example 1: Torkel's tool box
How can you easily cut around those tools?
Example 2: Camera
On the right side of this it looks easy. The left side around the camera with it's gentle curves, not so much.
Help, I need somebody. Help, not just anybody.
wae
UberDork
11/30/20 7:47 a.m.
I adapted one of the Harbor Freight hard cases to carry some shoes last year and it took some work, given the shape that I needed to work around. The Apache cases have the foam that's already cut up into perforated blocks so I laid the shoes on the foam and went around the edges with a marker. Since I was working in three dimensions, I went a single layer at a time and basically lowered the shoe into the foam.
I've also worked with foam that doesn't have the perforated sections and you've got a couple options for that. If the foam is pretty dense, you can cut the outline with a hot knife and then carve it out with a rotary tool to get a cavity. That's not the most exact way to do it, though, so I like to work with multiple layers. You can use two thin layers with the first being cut all the way through around the outline of the thing and then glue it to a solid bottom layer with something like construction adhesive or Gorilla spray glue. If it's complex shape, you can use more thin layers to build it out.
noddaz
UltraDork
11/30/20 9:31 a.m.
That is what I was afraid of. I guess if it is worth doing, I might as well do it right.
CAinCA
Reader
11/30/20 10:47 a.m.
I've used an electric carving knife for bigger/chunkier items.
In reply to CAinCA :
For that matter, a good bread knife works fairly well when shaping foam for seats. Not sure if you could get good enough for tool shadowing, but maybe.
thedoc
Reader
11/30/20 8:12 p.m.
Where does on buy a "hot knife"? I know where to by a Saturday night special, but the knife is new to me...
Got a soldering gun? Bend an old coat hanger into a useful shape, screw it into the upper and lower holders, get it hot, and go to town.
0
thedoc
Reader
12/1/20 2:31 p.m.
In reply to Appleseed :Thanks Man!
Mr_Asa
SuperDork
12/16/20 8:13 a.m.
For sockets you can just put em on a drill and spin them into the foam.
This is kinda late reply but there might be somebody still care about this. I personally use a hot knife. The key is, go straight across and don't press too hard, just press lighter. This makes it easier to cut foam into pieces.
Hot knife has been my go to.
