TurboFource
TurboFource New Reader
7/13/22 7:18 p.m.
WonkoTheSane
WonkoTheSane UltraDork
7/13/22 10:26 p.m.
nice setup, that looks quite handy!
bearmtnmartin (Forum Supporter)
bearmtnmartin (Forum Supporter) UltraDork
7/13/22 10:30 p.m.
I just use a heavy piece of angle iron.
7/13/22 11:07 p.m.
In reply to bearmtnmartin (Forum Supporter) :
I think the notches allow more torch clearance so more wrap per bead, and less start/stop.
TurboFource
7/14/22 7:54 a.m.
It's lightweight, easy to cut and adapt, and wood doesn't scratch things up easily.
I try to get 3 good tacks about 120 degrees apart...
Of course don't catch it on fire!
NOT A TA
NOT A TA UltraDork
7/14/22 9:19 a.m.
Another way is to use a worm gear hose clamp with 3 windows cut out of the worm drive slots. Spot weld in each window, remove clamp and finish welding.
7/14/22 10:26 a.m.
i would end up land-locking the clamp to my tubes.  i suck at this game.
frenchyd
frenchyd MegaDork
7/14/22 10:33 a.m.
I use aluminum angle  when I'm welding steel and steel angle when I'm welding aluminum.
That justifies keep scraps sound.
TurboFource
TurboFource Reader
8/26/22 7:53 a.m.
I made it in GRM with this!!
Here's another wooden fixture...
BimmerMaven
BimmerMaven New Reader
11/3/22 8:35 p.m.
With angle or channel....cut a notch for welding clearance.
Bevel corner so welding clamp doesn't slide.
kRFkcbVT8apJMmm1WFEWXCYQ9SAZTHGq8EZ65bvoLVjIZcdTHib8ZTHa8h59AcS4
