Restoration Impossible: Engine Meets Frame
Tim
Update by Tim Suddard to the Lotus Elan project car
Dec 22, 2017
We used our lift to raise the engine/gearbox combination and gently rested it onto the engine and transmission mounts.
While the gearbox mount fit fine, we could not figure out how to fill the gap between the engine mounts and the engine. After making a few calls we learn that the odd tubular 1 1/8-inch spacers sitting in our parts bin were supposed to be used on the left side of the engine block to move the engine mount closer to the Elan’s frame.
While this was just about the wackiest engine mounting system we had ever witnessed, it worked perfectly.
Once the engine and gearbox were fitted we could connect the driveshaft—which we had placed inside the frame earlier.
Sadly we soon learned that the later 3.7:1 final drive we had fitted from a newer Series 4 Elan—versus the original 3.9:1—had a different sized yoke than the earlier style differential.
Thankfully, we had another yoke that we had on a spare later style driveshaft. We managed to get the problem driveshaft out of the frame and easily make the swap without taking the engine back out.
gjz30075
gjz30075 HalfDork
12/23/17 5:45 a.m.
Looks good!     You may or may not know this but you'll have to remove the carbs  and the rearmost carb studs to fit the
body.     You probably do know this and the carbs are mounted for picture purposes :-)
Tim Suddard
Tim Suddard Publisher
12/31/17 8:11 a.m.
Yes, we know that the carbs, heater valve and even the studs that hold the carbs on need to be removed. This was done to make what we think is a super cool picture of a naked Elan.
APEowner
APEowner HalfDork
12/31/17 5:32 p.m.
I too think it's a super cool picture
Lester
Lester New Reader
2/5/18 9:03 a.m.
Brings back memories of when i did mine in 1974-79. The 3.9 diff works better with the Close ratio Gearbox.It is better for sprinting. When driving it ,you always wished you had a 5th O/drive, like the last +2 had.The beauty of the 3.9 with the Close ratio box is 1000rpm 'tween Shifts......sweet.
Your project is giving me the incentive to bring my S2 out of 15 years of storage.I need to refinish my 40year old restoration.What was you Gel Coat material?
firstaccessinc
firstaccessinc New Reader
2/6/18 5:19 a.m.
In reply to Tim Suddard :
WOW!!! It's amazing.......
Tim Suddard
2/25/18 8:29 a.m.
Thanks guys. We have been killing oursleves, but will have it at Amelia.
wheelsmithy
wheelsmithy Dork
2/25/18 9:40 a.m.
body.
I get the carbs, but you have to remove the rearmost studs! That's built tight. Love it.
Tim Suddard
3/14/18 7:42 p.m.
Yes, I did have to remove those studs wheelsmithy
Sponsored by
Classic Motorsports House Ad
Mp7zDx1HywzCXwETnFsi1D2ZqbxNvrZhqAadTshmzfyHuJJVeFEWwRxWSpPLf2Zq
