Power From Below
Per
Update by Per Schroeder to the BMW 2002tii project car
Jan 23, 2012
The best way to install an engine in a BMW 2002 is from the bottom. This requires removing the front subframe.
A Spec aluminum flywheel helps us drop about 10 pounds off the car—and out of the rotating mass of the drivetrain.
Spec recommended that we use their Stage 2 clutch kit.
The transmission is now mated back up with the long block.
We are in the home stretch with the engine under the car.
The factory installs the engine and subframe from the bottom, which is a lot easier than trying to angle the engine/transmission combo into the short engine bay from the top.
Once the dressed long block was assembled on the engine stand, we switched gears: We dropped the front subframe and jacked the nose of the car way up in the air. The factory installs the engine and subframe from the bottom, which is a lot easier than trying to angle the engine/transmission combo into the short engine bay from the top. We took the time to degrease the subframe and give it a coat of Eastwood‘s Chassis Black paint.
We took our engine hoist and transferred the engine to the cleaned-up subframe. We will be using an ATV jack from Harbor Freight to lift the entire assembly back into the car.
Before we mated the transmission to the engine, we installed a Spec Clutch aluminum flywheel and high performance clutch. The Street Prepared Rules allow for these parts, so now is the perfect time to improve our car’s performance.
With the engine and transmission mated up, we then slid the entire kit and caboodle under the lifted BMW. At this point, the bottom of the front air dam is nearly 30 inches off the ground. We then carefully lowered the nose about 10 inches on its jack stands to button up the last few parts.
Do you like web updates like this? Get the whole story on all of our project cars in the pages of Classic Motorsports magazine. Subscribe to Classic Motorsports today!
buzzard
buzzard None
1/24/12 7:55 a.m.
Love this car ...and the progress is fun to watch...it will be a blast to get on the road I am sure.
Sponsored by
Bavarian Autosport
z29LfZCGn7EAmMncFypdLsrtjpr8JIxiRruwet2J6OyYkSSiCbSq2ezQ7SCH0Ezl
