Rotisserie restoration? How about a tip-tisserie restoration? | Video
https://www.youtube.com/embed/LWLotuKJ0UU
Want the advantages an automotive rotisserie offers when working on a project car without having to shell out thousands of dollars?
Lucky for you, forum user TheWraith has the perfect solution, the tip-tisserie–made with less than $100 worth of wood.
See more of the tip-tisserie in the build thread: Big G Body Build and 50 Other Distractions.
JAdams
JAdams Reader
10/20/21 1:51 p.m.
Made years ago that was $100 worth of wood, but I see at least $1000 there these days...
Kidding (kinda).
Dusterbd13-michael
Dusterbd13-michael MegaDork
10/20/21 2:10 p.m.
I need one.
That will support an entire car minus engine and trans....
Honsch
Honsch Reader
10/20/21 3:36 p.m.
When we built our Fox wagon, I built one out of some cheap steel, pivots and all.  I think it was around $100 in parts six years ago.
It bolted to the car in the stock bumper mounts.
GM > MG
GM > MG New Reader
10/20/21 7:05 p.m.
Dusterbd13-michael said:
I need one.
Dude...
I practically live next door to you. Want mine?
Had my MGB GT on loaded on it w/ motor, trans., and front/rear suspension. No doors hood, front fenders or any interior - Say 1300-1400 lbg ?
I do need back what I have into it - $800 pre-pandemic.
Probably close to one billion dollars in todays steel $$$...
NOHOME MegaDork
10/20/21 7:34 p.m.
Best part of the wood version is that you have firewood when you are done.
In my experience the spinner is in the way the day the car comes off of it. I cut mine up and scrapped most of it just for the room; nobody wanted to buy it.
californiamilleghia
californiamilleghia UltraDork
10/20/21 8:03 p.m.
are there any plans / drawings  for the wood one ?
mostly need to know the radius on the curved part.....I guess the rest will matter how large or small your car body is......
Thanks
Wicked93gs
Wicked93gs Reader
10/20/21 8:56 p.m.
While wood "tippers" are great for budget...they are not as good for a full on restoration. During the course of my restoration I can't even tell you how many times I needed the car fully upside down to be able to get to something, especially when it comes to painting the undercarriage and interior. In the end...I just ended up borrowing a full rotisserie from a friend for a couple months. If I didn't have that option I would have built a tipper and spent many an hour cursing and clambering up and down some type of scaffold.
frenchyd
frenchyd UltimaDork
10/21/21 9:52 a.m.
I built a steel rotisserie  out of scrap metal I found in a dumpster.  I'm still using it 45 years later because it takes up so little room to store in the garage.
     With the aide  of a stick welder, a cheap metal cutting bandsaw  I had it built in one morning, and my car up on it that afternoon.  I laid the pieces on the floor of my garage and when I had enough for 2 legs I built one leg and then laid the second leg on top to duplicate it. No measure, No plans, just cut, and weld. Guessing, there is about $200 worth of steel if I had to buy it.
frenchyd
frenchyd UltimaDork
10/21/21 9:56 a.m.
Sorta depends on if you ever see doing another car or not.  Even when I thought those days were over. I kept mine because  I knew sooner or later that steel would come in handy.
TheWraith
TheWraith New Reader
10/21/21 7:49 p.m.
I need one.
I'd beef it up a little more on the uprights but it should, it had zero problems with the body.
You'll need to Log in to post comments.
eN81DgqU24Vti64F1tbLdQQhyDII55mhdFH3BUmnvn4tlZQBTaEV8fYhkLDSyNQY
