Suspension Bushing Removal Techniques
https://www.youtube.com/embed/7MG7hBJbQ38
On this episode of GRM Live! Presented by CRC Industries we're exploring a few different methods for removing troublesome suspension bushings, including the right way, the easy way, the safe way, and the best way (not necessarily the same).
Watch More Grassroots Motorsports Videos.
Patrick
Patrick MegaDork
1/3/20 12:43 p.m.
If it's anything like my datsun mustache bar bushings, the correct answer is set ablaze and go have dinner where the smoke isn't.
Toebra
Toebra Dork
1/3/20 1:01 p.m.
I always press them in and out, got the right tools for the job for like $50.  Did the Miata last year, relatively painless.  I am sure was way easier than motor mounts, oxygen sensors and catalytic convertor are going to be.  Just time consuming.
KyAllroad (Jeremy)
KyAllroad (Jeremy) UltimaDork
1/3/20 1:43 p.m.
Hmmm, when I did my NA Miata bushings the advice I was given was to heat the metal around the bushing until it started to smoke, then knock out the bushing with a deep well socket.  It isn't as dramatic as setting the whole thing on fire but it was much quicker and less stinky.  And due to the conduction of heat I don't believe I got the metal any hotter than you did.
DeadSkunk  (Warren)
DeadSkunk (Warren) PowerDork
1/3/20 1:47 p.m.
In reply to KyAllroad (Jeremy) :
I did my NB by using a Harbor Freight heat gun and a homemade sleeve with a bunch of long bolts.  The sleeve was a 3" piece of roll cage tubing.
NickD PowerDork
1/3/20 1:50 p.m.
When I did the bushings in my NA, I tried heating around them, but after 25 years, they were in there good. I ended up having to resort to setting them mildly on fire while pushing on them with a punch to get them to pop loose. Dirty, smelly, sticky work.
KyAllroad (Jeremy)
1/3/20 2:15 p.m.
Oh FSM!  I can't imagine the heat gun was doing you any good at all.
BTW, I did try to press them out using a 12 ton HF shop press.  It did not have enough grunt and ended up bending the push shaft.  I tried the drillbit trick and it failed for me as well.  "Heat it till it smokes" worked beautifully.
Streetwiseguy
Streetwiseguy MegaDork
1/3/20 4:35 p.m.
Pushing new bushings in is several orders of magnitude easier than pushing an old one out.  I have the factory supplied tools to remove several different Volvo suspension bushings, and I think I'd be lying if I said they worked 25% of the time for removal.
Flame wrench to the rescue.
tr8todd
tr8todd SuperDork
1/3/20 4:40 p.m.
Soak them in a bucket of gas overnight and then set on fire.  Spectacular!
Shadeux
Shadeux Reader
1/3/20 5:10 p.m.
I thought wielding a sledgehammer while screaming at the offending part usually worked.
DeadSkunk  (Warren)
1/3/20 7:39 p.m.
The heat gun is good for 800-900 degrees. The bushings were getting gooey on the surface. I could put the bushings under tension with the bolts and sleeve and then hit them with the heat . You could hear them release from the steel A-arms. A torch would have been quicker, but I don't have one.
You'll need to Log in to post comments.
gMJqulBisBpvQrW022GiOteYKIz3usnrqKn8oAyBC9UWfqmDSuY9nJe40vfdMwsl
