Video: How to use a tap and die set
https://www.youtube.com/embed/QpFr_RbBd90
A tap and die set is useful if you need to clean threads or even make new ones, but it can be easier than you realize to make mistakes.
Here is how to effectively use a tap and die set, as well as some useful tips we’ve picked up thanks to the numerous project cars we’ve worked on over the years.
Presented by CRC Industries.
Torqued
Torqued New Reader
3/19/21 11:21 p.m.
There have been times when I have needed to cut a bolt shorter and didn't have a die available to straighten the cut threads or didn't have one in the right size.  In that situation it helped to first run a nut down on the bolt before cutting it, then running the nut back up and off the bolt will help straighten the threads that werre bunged up by the hacksaw.
You'll need to Log in to post comments.
buInK03ANnGdf0a683r8QdfkJ1nTTr0HfqwlrOKG7belRGuIiGXFfVOps3GTyV23
