Video: Listen to Honda's Only Production Five-Cylinder Engine
https://www.youtube.com/embed/WbU5IkzUnJE
Honda may be known for its high-revving inline-fours, but did you know that they also produced a five-cylinder engine? Known as the G-series, this engine saw limited use in the Honda Ascot, Rafaga and Inspire in Japan, as well as the U.S.-market Acura Vigor and the later TL. Listen to a G-series at VIR.
Like what you're reading? We rely on your financial support. For as little as $3, you can support Grassroots Motorsports by becoming a Patron today.
Tom1200
Tom1200 Dork
6/3/20 9:35 a.m.
Are the motors RWD compatible?
6/3/20 9:48 a.m.
In reply to Tom1200 :
I'm not certain. The engine is mounted longitudinally, but the aftermarket for the G-Series is pretty limited considering it's not particularly popular.
It would make for quite the swap, though, if you could figure out how to make it work.
aw614
aw614 Reader
6/3/20 10:22 a.m.
Werent they originally rumored to go in the S2000 before they went with the F20c? I recall reading several  90s era Car Magazines mentioning the Honda SSM concept had a 5 cylinder.
Tom1200
Tom1200 Dork
6/3/20 11:13 a.m.
I have a 1600lb car so the stock 190hp would be more than enough. I do know the motors can be had pretty cheaply.
Woody
Woody MegaDork
6/3/20 11:24 a.m.
I always thought this would make a great mid engine rwd donor.
Robbie (Forum Supporter)
6/3/20 11:32 a.m.
huh. the 1991 - 1994 acura vigor had the 2.5l i5, logitudinal mounting, manual trans, and limited slip diff. (engine is basically behind the drive wheels though, 'mid-front'wd design).
Would make a really cool swap I think.
CrustyRedXpress (Forum Supporter)
CrustyRedXpress (Forum Supporter) Reader
6/3/20 11:40 a.m.
My first thought was, "Well this is obviously what we should put into the GRM europa."
6/3/20 11:52 a.m.
In reply to aw614 :
Sure seems that way. I wouldn't be surprised if the engine itself was a F-series with an additional cylinder.
https://www.carthrottle.com/post/remembering-the-five-cylinder-concept-that-became-the-honda-s2000/
6/3/20 11:55 a.m.
I like the way you think. Actually, this drivetrain should be a good fit into a stock europa frame, based on what I know about europas.
bobzilla
bobzilla MegaDork
6/3/20 12:20 p.m.
I remember the 2.5TL that replaced the Vigor from 95-97 had issues with manifolds cracking. They had the cat integrated so it wasn't cheap. I'd recommend the Vigor (still cracked them but no cat).
You'll need to Log in to post comments.
G7zjHTUZMgT6Kn8M6seFAMSj9icN3Geu0jPZVbuigzaFM0se4x8fb0qbGCvZtkqR
