I'm having to manually cycle it each time.
In reply to Floating Doc :
Sounds like a classic case of failure to feed. Weak magazine spring? (applies to staplers)
Thanks, that sounds right. Can't access the mechanism
When is the last time you've cleaned it? Unless you're shooting a Kalashnikov, stablers care about being clean.
Ian F
MegaDork
12/26/18 12:48 p.m.
Sounds like you need a proper stapler...
Broken spring. Not likely to be able to get parts.
I have two of these at home. They're tanks, the old Swinglines. mine are decades old.
I believe that would be classifed as a manually operated repeater, rather than a semiautomatic.
