2 3 4 5 6
CrustyRedXpress
CrustyRedXpress New Reader
10/18/19 8:55 p.m.
Question on battery tie downs-
My battery is in it's stock location and utilizes original wiring, but is an AGM turned on it's side. It meets the first part of the rule, "Removable, reusable battery tie down made of metal" but not the second, "(NHRA requires a metal strap or minimum diameter 3/8th inch threaded rod.)" See pic below, metal rod is 3/16ths. Am I ok? If not, what should change?
Question on Firewalls-
I haven't modified the firewall, but have removed the heater and AC hoses that went through it. Do I have to plug these holes?
Thanks!
davbro
davbro New Reader
10/19/19 5:48 p.m.
Are "headlights" considered a safety item? If yes are they excluded from the budget?
maschinenbau
maschinenbau SuperDork
10/19/19 5:58 p.m.
In reply to davbro :
If it's not explicitly excluded in the rules, it goes in the budget. A lot of safety items like roll bar are to be included in the budget. From what I can gather, headlights are too.
maschinenbau
10/19/19 6:02 p.m.
In reply to CrustyRedXpress :
Tough one on the battery. Stock location, but obviously not a stock tie down. I would upgrade the threaded rod to 3/8 to be safe, if you can do so easily. Battery tie down are a common tech inspection failure.
Patrick
Patrick MegaDork
10/19/19 6:45 p.m.
Yeah C R X, i think unless your rods are 3/8 they're going to fail.
CrustyRedXpress
10/19/19 7:40 p.m.
In reply to maschinenbau and Patrick:
Good enough for me-I'll upgrade the rods to 3/8ths tomorrow. Any thoughts on the AC/Heater hose holes in the firewall?
maschinenbau
10/19/19 7:50 p.m.
Make it look solid and probably be good. Grommets, rubber plugs, whatever.
Patrick
Patrick MegaDork
10/19/19 8:06 p.m.
Yeah, holey firewall is a no-go.  Maybe the electric row at home depot will give you some plugs.  With my datsun i was literally out of budget in 2015 so i cut up an empty brake cleaner can for firewall hole patch.
davbro
davbro New Reader
10/20/19 12:22 a.m.
If you built your challenge car in 2016 you were allowed to recoup up to $1008 regardless of purchase price of car.  is the calculation grandfathered in?  we are required based on the FAQ to submit budget on new spreadsheet
bobzilla
bobzilla MegaDork
10/20/19 6:43 p.m.
Ok, rules say 3-ring binder. My build is fairly short and straight forward so I currently have it in this :
3-ring folder. Ok or gotta buy the actual 3-ringer?
AngryCorvair
AngryCorvair MegaDork
10/20/19 7:35 p.m.
My build book is just a cover page.
2001 Sonoma:  $2000
the end.
Pete Gossett
Pete Gossett MegaDork
10/20/19 7:39 p.m.
In reply to AngryCorvair :
After building the Vette for 2017, if I ever field another entry I’m going to follow your lead with the Sonoma.
slowbird
slowbird HalfDork
10/20/19 9:14 p.m.
In reply to bobzilla :
I'm cool with the folder you've got there, but there's 3-ring binders at the dollar store if you wanna play it safe.
that's where I got mine.
Bent-Valve
Bent-Valve Reader
10/20/19 11:06 p.m.
I didn't like my battery hold down anyway. Add 3/8ths upgrade to tomorrow's to do list.
Tom Suddard
10/21/19 6:50 a.m.
You'll need bigger threaded rod. And yes, all firewall holes must be covered.
Tom Suddard
10/21/19 6:51 a.m.
No, the only safety exemptions are those listed in the rules.
Tom Suddard
10/21/19 6:52 a.m.
Sorry, needs to be an actual binder. Those suck to lay on a desk and flip through.
Tom Suddard
10/21/19 6:54 a.m.
There's no official grandfathering rule, but we can let some things slide on a case-by-case basis for returning challengers. Do you not have $8 of room in your budget?
bobzilla
bobzilla MegaDork
10/21/19 8:39 a.m.
In reply to Tom Suddard :
Got it.
surfshibby07
surfshibby07 Reader
10/21/19 9:14 a.m.
I have a budget question. So i plan on wearing an old flightsuit i have from when i was in the navy during the concourse. since this was just a standard issue item while i was in the military do i need to list this as fair market value?
AngryCorvair
10/21/19 9:18 a.m.
In reply to surfshibby07 :
driver clothing is not part of budget
bluej
bluej UberDork
10/21/19 9:34 a.m.
Is a lay-flat, spiral bound book ok? I already put a fair amount of effort into laying out a cohesive published package.
surfshibby07
surfshibby07 Reader
10/21/19 9:42 a.m.
ok i didnt think so but since it isnt "traditional clothing" i wasnt sure. thank you.
Tom Suddard
10/21/19 9:58 a.m.
In reply to bluej :
Technically no, but I doubt anybody would file a protest over that. Just know that if they do, it's pretty cut and dry in the rules that it must be a three-ring binder.
SVreX
SVreX MegaDork
10/22/19 6:39 a.m.
Tom, I think you misunderstood the question.
In 2016, the wording of the recoup rule appeared to allow recouping the FULL amount, regardless of the purchase price. It enabled a theoretical negative budget.
So, if a car was purchased for $1, the full $1008 recoup could be applied to THAT purchase.
Current rules clarify that recoup cannot exceed the vehicle or parts purchase amount.
Its not an $8 question. It’s potentially much more.
2 3 4 5 6
This topic is locked. No further posts are being accepted.
kUZZhheIzmpzfZneQdzeO7UBCifdFnPef7RKibFid8vAo7DHAwuEyiJPGYvXYHCN
