The good: OBX LSD Si trans/dx final Avid traction bars K-sport full coilovers full energy suspension bushings Newer lower ball joints adjustable upper ball joints cheapo header back exhaust for hatch w/ fart can added out back (very quiet) fidanza 7.5lb flywheel clutch specialties unsprung 6-puk brand new OEM clutch cable short shifter Sony CD player 8" bazooka tube new stock rear drum brakes Ex 10.5" front brakes/spindles & MC
The bad: needs an axle seal minor rust & body damage tach in indiglo gauges is busted aftermarket sunroof
Spares: axles strut bars Y8 manifold MPFI distributor OEM power lock things OEM front power window regulators disassembled D15b2
Other: In the mail I should have a PM6 ECU, stock upper control arms, Si gauge cluster, and a few other things coming that will be included or installed if I have time.
Don't really want to sell it, but I'm moving and won't have space to keep it. Located in Cedar Rapids, IA. 319-329-468
Drives like it's on rails, was building it for auto-x, with a small turbo planned. Swap out the dx final for the si final to run it N/A.
Sorry about the formatting, I tried using < br >, it works in the preview but goes away when I publish it.
oh, lol, I put that needle on wrong. I took that cluster out right after the pics because the tach is busted too. Original cluster shows normal temps, and I've put a few thousand miles on it w/o problems.
Axle seal replacement is very easy, FWIW. The hardest part for me was finding the correct part for my RT4WD model. All in all it's in great shape for a rust belt Civic of that vintage. Good luck!
