3 4 5
bigfranks84
bigfranks84 New Reader
3/10/18 12:59 a.m.
Hp48 work good on an ej22? Its a na motor, that I just plan on running a fmu on , when I get around to it eventually. Because 130hp won't be enough in the Ghia...
whiskey_business
whiskey_business Reader
3/10/18 8:41 p.m.
In reply to bigfranks84 :
For low boost on a smaller engine like that, should be a pretty good fit. Gotta say I love all the awesome projects these are going on!
captainawesome
captainawesome HalfDork
2/17/20 1:38 p.m.
BTT
I bought one of these HP48s a couple years back and it's just sitting on a shelf. Never been used. Anyone want one for $175 shipped? Trying to drum up some spare cash for an upcoming track day cause taxes are due but I still wanna party. Help me, help you.
fritzsch
fritzsch Dork
2/18/20 7:42 p.m.
In reply to captainawesome :
PM sent
Lof8 - Andy
Lof8 - Andy SuperDork
2/18/20 8:10 p.m.
Also PM'd. 2nd in line.
captainawesome
2/18/20 8:21 p.m.
Messages sent!
bluej
bluej UberDork
2/21/20 12:51 p.m.
Bumping this to the top again in case Whiskey Business is still around, and to maybe get some others's input. I had bought the two used hp65's way back when, and am finally getting to using one on a challenge build.
My best calculations for realistic max target HP/RPM (2.5L) put me in the 2.15 pressure range, and ~.30 Kg/S. That puts me out of both the 60% efficiency island, and past the 160k rpm's line.  Looking at the trends of the curves on the map, I think we could assume that would put the compressor speed at ~170k rpms at that point. With a 60.5mm comp wheel diameter, that would be ~540 m/s at the tips.  Is that safe to plan for as a max?
Here's the comp map:
whiskey_business
2/21/20 1:54 p.m.
In reply to bluej :
Definitely still around! Without having to pull a bunch of spark timing to prevent knock, that 0.3 kg/s (40 lb/min) range should land you in the 400hp range. That is definitely further than I think these turbos will like to be pushed. No guarantees on how long they would last at that power level, or if they will even flow enough on the turbine side to support that.
As a side note, I have some of these turbos left as well as some larger stuff that I bought for other projects.
bluej, if you are still shooting for that much power I might be able to help you out.
bluej
bluej UberDork
2/21/20 2:56 p.m.
Yeah, that's one of the things I liked, that these are sized for faster response. I'm trying to figure out what a max practical limit is, knowing I'll end up at the end of the turbo and cam happy place . Redline is going to be at, or not much past 6k. Do you have ANY other info about these you'd be able to send me?  Thanks!
maschinenbau
maschinenbau SuperDork
2/21/20 3:06 p.m.
In reply to whiskey_business :
...which turbos do you still have?
captdownshift
captdownshift UltimaDork
2/22/20 10:17 p.m.
Curious about some of the larger stuff
whiskey_business
2/25/20 1:37 p.m.
In reply to maschinenbau :
Still have a number of HP48 and HP65s. Theyre in the garage, I'll check numbers if anyone is interested.
Also have the following generic China turbos, one of each. I'd like to keep these challenge friendly priced, so let me know what works if anyone is interested:
"GT"2876 Internal Wastegate
"GT"3076 Internal Wastegate
"GT"3582 Non-gated
"GT"45 Non-gated
"GT"4092 Big daddy non-gated diesel turbo
I think I'd like to keep the 3582 for my Sonoma project, but all are able to go.
bluej
bluej UberDork
2/25/20 3:06 p.m.
I may be interested in the 2876. specs on the hotside?
captdownshift
2/25/20 5:14 p.m.
In reply to bluej :
Damn beat me to it
bluej
bluej UberDork
2/27/20 12:05 p.m.
Message sent.. devil
captdownshift
3/1/20 7:19 p.m.
In reply to bluej :
Haha it's dibs by your post.
whiskey_business
3/1/20 8:29 p.m.
Sorry for the slow response, turbos are stored under my desk at work.
BlueJ, I'll respond with specs as soon as I verify them on the turbo.
Everyone else, I'll post more info tomorrow.
Mr_Asa
Mr_Asa HalfDork
3/1/20 8:49 p.m.
"GT"3582 Non-gated
"GT"45 Non-gated
I need to brush up on my turbo knowledge. Know if either of the T04 flanges will play well with a Ford 300 Inline 6?
Mr_Asa
Mr_Asa HalfDork
3/1/20 8:55 p.m.
I guess I could redesign the adapter for a T3 flange.  I haven't poured it yet so I might as well of that works better.
Strike_Zero
Strike_Zero UltraDork
3/2/20 2:08 p.m.
Would the "GT"3076 Internal Wastegate turbo be a good fit for GM 3500 V6 (220hp variant) limited to 6500rpm?
The car will be relatively light (sub 2300).
Patrick
Patrick MegaDork
3/2/20 7:28 p.m.
How much for the 4092 for a hopeful challenge build?  Can pick up or make Angry come get it and store it.
whiskey_business
3/2/20 8:31 p.m.
In reply to bluej :
Specs on the 2876 are as follows:
Compressor Housing: A/R 70
Compressor Wheel(in/out): 54.3-82
Turbine Housing: A/R 86
Turbine Wheel(out/in): 46.2-53
Water and Oil Cooled
Journal Bearing
T25 flange
5 Bolt Outlet
Internally Gated
Specs on the 3076:
Compressor Housing A/R: A/R.70-Ф54.3 -82
Turbine Housing A/R: A/R.86-Ф46.2-53
T25 flange
5bolt with V-Band Adapter
Internally gated
Specs on 3852
Compressor Housing  : A/R.70
Compressor Wheel(in/out): Ф61.4-Ф82
Turbine Housing : A/R1.06
Turbine Wheel(out/in):  Ф62.3-Ф68
Water & Oil Cooled
Journal bearing
T3 Inlet
4 Bolt Outlet
Specs on the 45R
Compressor Housing:(Two) A/R 70
Compressor Wheel(in/out): 61.4-82
Turbine Housing: A/R 1.00
Turbine Wheel(out/in): 64.5-73.8
Oil cooled
Journal Bearing
Not Gated
T4 Divided Inlet
V-Band Outlet
Specs on the 4202 (Not 4092 like I originally thought
Compressor Housing  : A/R.60
Compressor Wheel(in/out): Ф74.8-Ф102.4
Turbine Housing : A/R1.05
Turbine Wheel(out/in):  Ф75.2-Ф82
Oil Cooled
Journal bearing
Not Gated
T4 Divided Inlet
6-Bolt (Diesel style)Outlet
In reply to Strike_Zero :
It's honestly a pretty good match for the 350-450hp range. . . That would be a rocketship with a light weight car.
In reply to Patrick:
I'm thinking in the ~$225 range for all of these things, will work with people if they can make a case for fitting it into the budget or onto something especially cool.
bluej
bluej UberDork
3/3/20 8:07 a.m.
I'll pass on the 2876, thanks though.
bigben
bigben Reader
3/4/20 10:26 p.m.
Is the v-band adapter the only difference between the 2876 and 3076? The specs look the same.
3 4 5
2YtlfD0la4amF9ufdw1j2eCcFJSDlq70m37VJ48r8pMBGYeuVbixqwM4v6LtCySS
