7/17/23 10:26 a.m.
EDIT:  Nevermind, i found something to try.
i'm looking for squirrel cage blower with enclosure, 12V, in the ballpark of 4-6" OD.  thinking there's got to be some small-ish car heater / defroster that would use something similar, but most of the enclosures i'm seeing in my basic search are part of a much larger assembly.
suggestions?
Thanks!
Jesse Ransom
Jesse Ransom UltimaDork
7/17/23 10:57 a.m.
I'm guessing this is fighting Challenge budget, so the couple of options at McMaster-Carr are out. It makes sense that the actual automotive stuff is all built in unit with heat exchangers.
I'd try Banggood or Vevor or similar for a cheap fan.
Many years ago I bought a cheap package tray defrost fan at the local discount parts place when such a thing existed. I can't imagine there's been a market in decades.
Jesse Ransom
7/17/23 10:59 a.m.
How much air do you need to move? There are tiny ones that go for down around $10, but you'd probably need two or more, and it still wouldn't probably be a fast defrost...
classicJackets (FS)
classicJackets (FS) SuperDork
7/17/23 11:07 a.m.
Z car guys use a Kia Sportage part that's available in junkyards pretty easily, if you want a starting point? Similar in size maybe?
7/17/23 11:12 a.m.
In reply to Jesse Ransom :
Doh! i didn't state the application.  I'm going to use these to blow air through MonZora's header heat shield boxes.
i bought a couple small plastic ones with tiny little wires on them, i'm guessing they're intended for desktop computer cooling? IIRC they're rated at 30 cfm. I haven't installed them yet because (1) i don't have the heat shields complete yet and (2) their outlets are rectangular.
i just ordered a couple of bilge fans, they're in-line vs squirrel cage. they are designed to slip-fit in 3" vent hose and should move about 120 cfm.  These will be much easier to mount and plumb, so i'll find a way to get them into the budget.
Dead_Sled
Dead_Sled HalfDork
7/17/23 11:37 a.m.
I was going to suggest bilge fans, the packaging makes them super easy for this application.
97-03 Cadillac Seville rear blower motor is a junkyard option.
I plan to use one to ventilate the back of the hearse.  I wanted something with adjustable speed and quieter than a bilge fan.  I'm sure there's a more compact and adaptable option out there for your application.
californiamilleghia
californiamilleghia UberDork
7/17/23 12:10 p.m.
Hi , where is this hiding on the Seville and do you also need to pull the dash switch ?
thanks for the info
Dead_Sled
Dead_Sled HalfDork
7/17/23 1:49 p.m.
Wow, I shouldn't post before coffee.  It'd be a 98-03 Seville (-04 if in Canada).  Not sure what blower is in that picture above, but this is the one I was thinking of.
I can get some in car pics and rough measurements tonight once swmbo gets home.
Dead_Sled
Dead_Sled HalfDork
7/17/23 2:32 p.m.
In reply to californiamilleghia :
Front of the center console.  There's a slider for speed and a knob to adjust the blend door on the back of the center console behind the arm rest (so it can be adjusted from the back seat).  I hope this means it's a stand alone system and doesn't need a computer or module to operate.  I can't find the FSM with the description of the system, but here's a diagram from the center console removal section.  Blower in red, blend door in green, exit in blue.
https://www.ebay.com/itm/165841839777
Dead_Sled
Dead_Sled HalfDork
7/17/23 2:40 p.m.
MuSTANK
MuSTANK Reader
7/23/23 11:00 a.m.
They have in-line blowers for air-cooled VW heater tubes, also in-line bilge pump blowers. Might these be the way to go?
7/23/23 1:34 p.m.
In reply to MuSTANK :
I have a pair of 3" in/out 12VDC bilge fans on order, bezos personally guarantees they'll be here by 10PM tomorrow.
7/23/23 1:36 p.m.
MuSTANK
MuSTANK Reader
7/23/23 4:54 p.m.
"bezos personally guarantees they'll be here by 10PM tomorrow."
We have an Amazon warehouse on the edge of town, I order stuff before lunch and it gets here well before supper. Weird, as I can begin tracking the package about ten minutes after I order it . . .
7/23/23 10:00 p.m.
I ordered them last Monday, Prime, arriving Thursday. Thursday came and went, new promise is 7/24 by 10PM.
MuSTANK
MuSTANK Reader
7/24/23 9:22 a.m.
Betcha that I could have ordered them for you, had them delivered to me across town and mailed them off to you in less time . . .
759NRNG
759NRNG PowerDork
8/3/23 6:25 p.m.
The fan assembly from my long since departed 1973 SAAB 99 sounds quite like those dimensional parameters.....newer is always betterr nebber mind
5RKoEbngWElny4NGiD5lKLVA9najlcHfzCY7N1wcqJ3cj6PUzy5AvSqJ1KP2KSvy
