Brett_Murphy
Brett_Murphy UltraDork
9/10/13 11:30 p.m.
NMNA, but it MIGHT BE SOON!
http://raleigh.craigslist.org/cto/4028722959.html
Somebody save me.
dorri732
dorri732 Reader
9/11/13 7:46 a.m.
Even needing an overhaul, that seems too good to be true.
Sil80redtop
Sil80redtop Reader
9/11/13 8:41 a.m.
Anyone know the specifics of Mazda's, 100k, "all things rotary" warranty?
Looks like I found my own answer:
http://www.autoblog.com/2008/06/05/mazda-extends-rotary-warranty-on-rx-8-to-100k-miles/
4cylndrfury
4cylndrfury MegaDork
9/11/13 8:46 a.m.
wonder how much geometry class it would take to get that drivetrain into an Exocet kit?
Brett_Murphy
9/11/13 10:35 a.m.
The warranty for the car is long gone, which is why prices for cars over 8 years old with engine problems are pretty low. Compared to FC RX-7s, there is a serious lack of used parts for the RX-8s, so overhauling an engine can run pretty close to the cost of just buying a factory reman engine, which is over $2k.
I've emailed the guy. I don't NEED 3 RX-8s, but at that price there is profit to be made.
Cotton
Cotton SuperDork
9/11/13 10:40 a.m.
what's an overhaul cost on one of those for a DIYer?
old_
old_ Reader
9/11/13 10:41 a.m.
LSx time!
Brett_Murphy
9/11/13 12:22 p.m.
Cotton, until you crack open the engine and find out what has to be done, you can't really say.
New rotor housings are $700-$800 EACH. An apex seal kit is $1500ish.
A reman engine from Mazda is north of $2k, but might not use all new parts.
I went and looked at it at lunch time. It is about a mile away from my house. I am seriously torn on buying this or not.
Swank Force One
Swank Force One MegaDork
9/11/13 12:25 p.m.
If that were close to me, i'd ditch my 93 Miata in a heartbeat and buy this instead.
Sil80redtop
Sil80redtop Reader
9/11/13 12:40 p.m.
http://www.hinsonsupercars.com/s-942-mazda-rx8-2003-present.aspx
Joshua
Joshua Dork
9/11/13 12:53 p.m.
If that were within 4 hours of me I'd buy it!
Brett_Murphy
9/11/13 12:59 p.m.
I'm going to have a shell for sale soon. Probably SOONER if I buy this, since as far as I know this one doesn't have a salvage title.
The shell will be priced low enough for somebody to buy it, do a budget engine swap and still make it under challenge money if they do it right. Stay tuned.
BoxheadTim
BoxheadTim PowerDork
9/11/13 1:03 p.m.
Brett_Murphy wrote: Cotton, until you crack open the engine and find out what has to be done, you can't really say. New rotor housings are $700-$800 EACH. An apex seal kit is $1500ish.
Atkins Rotary lists their more comprehensive rebuild kits including their apex seals plus the usual water seals and all that for $1200-$1300 for the RX8. Obviously those are without the rotor housings. Might be worth a look.
fidelity101
fidelity101 Dork
9/11/13 2:34 p.m.
It could be an ignition related failure which usually gets disguised as an engine failure which is only a few hundred dollar repair. I wish this was local I would snatch this.
And I would avoid atkins kits, lots of paper/cork gaskets. Rotary Aviation is worth the coin and very comparable in price.
bgkast
bgkast HalfDork
9/11/13 2:38 p.m.
buy it!
Brett_Murphy
9/11/13 2:39 p.m.
Fidelity, if I do get it a compression test is on the menu.
If this guy would just get back in touch with me, the deal would already be done.
Mazdax605
Mazdax605 SuperDork
9/12/13 10:09 a.m.
Found this one on the local CL.
http://capecod.craigslist.org/cto/4027250152.html
Called the seller, and he said it is silver(yuck!) but I may go look at it anyway. Any idea why it is hard starting when hot? Compression is my guess, but it could be other things. I asked him if he has had it looked at, and he says Mazda thinks it is either a fuel problem or compression, but he never had a compression test. No idea why you would do that if you have it at the dealer with a problem.
Mr_Clutch42
Mr_Clutch42 New Reader
9/13/13 1:18 p.m.
I live a fair distance to the seller and I like the styling of the RX-8. I never sat in the back of an RX-8 but I don't understand why people and manufacturers want to have a rear seat that is so tiny that a 5 year old kid can't fit. I would rather take the rear seat out or get a 2 seat sports car.
Mr_Clutch42
9/13/13 1:19 p.m.
If I had a few grand in my pocket I would consider buying it.
yamaha
yamaha PowerDork
9/13/13 1:32 p.m.
Updates Brett?
CGLockRacer
CGLockRacer Dork
9/13/13 1:33 p.m.
In reply to Mr_Clutch42:
I've had 6'2"+ person sit in the back of my RX-8 and be relatively comfortable. Not day trip comfortable, but maybe an hour or so. They are surprisingly roomy back there once seated. Getting in and out though is a bit tricky. Wouldn't want to try ti without the rear doors.
Gearheadotaku
Gearheadotaku UberDork
9/13/13 2:14 p.m.
re-man engines are only around 2K?! That seems really cheap. Warranty?
Ranger50
Ranger50 PowerDork
9/13/13 2:56 p.m.
In reply to Gearheadotaku:
23800 ENGINE, SHORT M/T W/O ANTI THEFT LABEL (MANUAL TRANSMISSION>CALIF) (MANUAL TRANSMISSION>FED/CAN) - 071016. Required: 001. W/O ANTI THEFT LABEL (MANUAL TRANSMISSION>USA/CAN) (MANUAL TRANSMISSION>HARD SUSP). Required: 001. $2001.00
23800 N3Y102200R00 ROTARY ENGINE SHORT 6MT W/ANTI THEFT LABEL (MANUAL TRANSMISSION>CALIF) (MANUAL TRANSMISSION>FED/CAN) 071016 -. Required: 001. $4996.52
This was for an 05.... http://www.jimellismazdaparts.com/showAssembly.aspx?ukey_assembly=297422&ukey_make=995&ukey_model=14370&modelYear=2005&ukey_category=20232
Warranty:
Warranty Mazda warranties their original equipment parts for a 1 year/12,000 miles from the date of purchase.
BoxheadTim
9/13/13 3:17 p.m.
In reply to Mazdax605:
Hard starting when hot is usually a compression issue on rotaries.
SlickDizzy
SlickDizzy UberDork
9/13/13 5:18 p.m.
Mr_Clutch42 wrote: I never sat in the back of an RX-8
So how would you know? I double dated in an RX-8 once and it was fine for the ladies in back.
In$urance.
oH607dugW8OM8lKQjX6Zex2foK3ZZZ2ye5but6rDY4KinRizTInXAiqgAbwQq6ks
