oldopelguy
oldopelguy HalfDork
2/9/09 9:21 a.m.
I'm getting pretty heavy into late-model LSx based motors, and facing an upcoming move I see no reason to drag around any of the traditional SBC stuff I have in the shop. Would like to sell the whole works in one lot, might consider parting things out for the right price. Shipping is expensive, but will deliver within 200 miles of 29671 (That includes Atlanta, Charlotte, Knoxville, and Savannah) or along the route between here and eastern SD (will consider changing route for the right $) for not a lot of gas $. Would like to get $350 for the following, but will take offers if you show up in-person with cash:
-1978 Chevy Suburban 350 engine, 150k or so, ran good and had good compression but puffed smoke on start-up, probably valve stem seals, 2-bolt main to the best of my knowledge, no intake but should have most of the brackets and such for the acessories
-1985 or 86 Corvette L98 350, under 100k but sat long enough to lock up, probably 2-bolt main but I haven't checked, all the TPI parts sold
-late 70's 400 small block heads with recent new valves and such, ready to run
-1984 Corvette Crossfire intake manifold, was planning on mounting a pair of carbs on it or using it with a pair of turbos, think I even have a sheet of 1/4" or 3/8" aluminum to make a custom top out of somewhere
-2 full gasket sets, some accessories for the front of the motors, exhaust manifolds, manual trans flywheels (should have 158 and 163 with clutches) and bell-housing, auto trans flex-plates, HEI distributor, starters, etc...
Should be enough there to bolt the 400 heads on the suburban motor and add intake and run it, or enough certainly to rebuild a couple of 350's. Might consider parting with a Corvette 4+3 tras as well, if someone wants to go that direction, will have to think about a price. Will also throw in a rebuilt by GM (but modified, one bolt hole cut off for mounting behind an adapter on my big-block Dodge) 4WD 700R4 with transfer case for another $200. Also have a couple of Marine out drive bell housings and mid-plates for race engine use, if they would do you any good.
Trades also considered, let me know what you have. Show up at my door, help me load it up in your truck, and you won't leave disappointed, price or parts, I promise. And for a GRMer I'll toss in a giant, oversized, slow spooling, crazy-hp turbocharger I happen to have from a Mack Truck. You know, just in case....
aussiesmg
aussiesmg Dork
2/9/09 1:03 p.m.
Where are you located? Interested
oldopelguy
oldopelguy HalfDork
2/9/09 1:18 p.m.
oldopelguy wrote: 29671
Which is half-way between Atlanta and Charlotte.
aussiesmg
aussiesmg Dork
2/9/09 1:21 p.m.
When does it need to be gone?
oldopelguy
oldopelguy HalfDork
2/9/09 1:25 p.m.
Will be moving hopefully before mid-May, would like it gone enough before then to not be tripping over it and know what I'll have left to move.
aussiesmg
aussiesmg Dork
2/9/09 1:31 p.m.
Would pick up at or during the Mitty work for you? Oh and what's the price on the 4 + 3
oldopelguy
oldopelguy HalfDork
2/9/09 1:43 p.m.
Still not sure I want to sell the 4+3, still thinking about it.
I'll be driving to SD at least twice before the Mitty, probably 3 times, hauling cars up to SD. Would be far easier for me if you to meet me somewhere down by Indianapolis or pay me the gas to swing up there and drop it off. Then I know it's sold and I'm not tripping over a truck load of parts for the next few months. Either way, I'm not going to consider it sold until I have cash in hand and I'd rather not take your $ until you see what all you're getting, just so you know where you stand if someone shows up with cash.
stan_d
stan_d Dork
2/9/09 4:06 p.m.
what s 4+3 trans
oldopelguy
oldopelguy HalfDork
2/9/09 4:18 p.m.
Corvette manual 4-speed with overdrive on the back that can be used in any of the top three gears, total of 7 gears.
stan_d
stan_d Dork
2/10/09 7:12 a.m.
cool but out of challenge price I am sure but if you are motivated I have a twin turbo challenge truck that I would love to convert from at to mt and I work in Indianapolis.
oldopelguy
oldopelguy HalfDork
2/11/09 7:06 p.m.
You'd want to do some research on the 4+3, it's not "normal" in a lot of ways and might not make the best swap candidate.
I do have an NV1500 (I think) 5-speed from a 4.3-S10 I'd sell for the $400.I have into it.
The 400 heads have roller rockers too, in case that's the deciding factor someone needed to push them over the edge. Pics on Craigslist add: http://greenville.craigslist.org/pts/1031179736.html
oldopelguy
oldopelguy HalfDork
2/17/09 11:40 p.m.
Everything is SOLD, thanks guys!
i4QlpMn6dezwZc9A4GOwrNbNOTpF9EHJDP2k5YChW1C9OQRN7DNvvSjkXypgArGd
