Lennyseleven
Lennyseleven New Reader
8/21/08 12:36 p.m.
Looking for a cheap 6 cylinder Falcon steering box, I have a 65, not sure which others years would match up.
thanks!
HappyAndy
HappyAndy New Reader
8/21/08 10:53 p.m.
whats wrong with the box in the car? or is it mia? If you have one and its not to sloppy it can be adjusted, I did one once and it came out ok, but I don't have my restoration book any more so I can't describe the procedure. because '65 uses a solid column I am not sure if a fairlane or mustang column will swap right in. I forgot to mention to check/replace the idler arm, it was more of a problem on my stang than the steering box was. also worn out inner bushings and spring perch bushings are also common causes of ill handling.
Lennyseleven
8/22/08 1:18 a.m.
Yea its crazy sloppy, I do need to see about adjusting it tho.
44Dwarf
44Dwarf New Reader
8/22/08 6:35 a.m.
Adjusting is easy. Look at the cover on top in-line with the output shaft you'll see a nut and a stud with an Allen hole on the end. Hold the stud via the Allen then loosen the nut a 1/2 turn. Screw the stud down 1/2 turn and try turning the wheels. Do this many times as needed BUT check for tight spots just off center of the steering wheel. If you find a tight spot back off 1/4 turn until gone.
44
xK1fEhCmCPQoGJPvOd8pSGJ60Z5FeqhcBG2PUqsRYZvTp2RycmqISIqEKUqwDkon
