paranoid_android74
paranoid_android74 Reader
7/8/13 8:59 a.m.
NMNA.
Bad karma, or bad luck? "needs fuel pump . it was off soaking and my mechanic died".
I think I would have left that detail out of the listing...
http://toledo.craigslist.org/cto/3885744075.html
(can't hot link at work apparently)
yamaha
yamaha UberDork
7/8/13 9:29 a.m.
Doesn't run and has more rust than mine........$3-400 should buy that, but the guy is probably smoking crack in Toledo anyways.
On a side note, after seeing that, I think I'll be taking my diving board bumpers off.......the front looks better without it.
irish44j
irish44j UberDork
7/8/13 9:14 p.m.
interesting that it has e30 wheels on the FRONT, which suggests that it has wheel spacers since bottlecaps supposedly don't fit over the brakes up front. When I towed mine home I had to put the e21 steelies on the front and the e30 wheels on the back for them to fit.....
kind of interested in what that big box in the backseat is. With good interior, car could be worth $500 or so.
And Yamaha....yeah, I'm definitely pulling the diving boards off mine too :)
Knurled
Knurled UberDork
7/8/13 9:20 p.m.
yamaha wrote: Doesn't run and has more rust than mine........
Man, I worked on an E46 last week with more rust than that.
Incidentally, someone will need to tell me in no uncertain terms why I don't want a E46 3nnix wagon. Working on the buggers isn't even enough to dissuade me...
Datsun310Guy
Datsun310Guy PowerDork
7/8/13 10:06 p.m.
Likey
yamaha
yamaha UberDork
7/9/13 1:42 a.m.
In reply to Knurled: I wouldn't turn anyone away from an e46 wagon.......
beans
beans Reader
7/9/13 11:07 a.m.
I'd suggest I could check it out for someone, but it looks to be in that giant toilet we local'ers call the East Side. I don't consort with '05ers.
crankwalk
crankwalk HalfDork
7/9/13 11:16 a.m.
That particular car has neat look to it. For a racecar, it looks fine. Street car= Money pit
The M10 is super easy to work on
yamaha
yamaha UberDork
7/9/13 12:26 p.m.
In reply to crankwalk:
I finally figured out how to adjust my idle and enrichment on the '77 The engine itself is a cakewalk. The MFI setup, not so much....
paranoid_android74
7/9/13 2:25 p.m.
This is exactly why I don't go to the "big" cities alone to look at cars, namely Detroit and Toledo.
I don't want what happened to his mechanic to happen to me!
beans wrote: I'd suggest I could check it out for someone, but it looks to be in that giant toilet we local'ers call the East Side. I don't consort with '05ers.
paranoid_android74
7/9/13 2:27 p.m.
By the by, did these engines use the Solex carbs?
I have one in my basement that is free to a good home if someone wants to pay shipping.
It came on my MG (long story).
yamaha wrote: In reply to crankwalk: I finally figured out how to adjust my idle and enrichment on the '77 The engine itself is a cakewalk. The MFI setup, not so much....
crankwalk
crankwalk HalfDork
7/9/13 2:40 p.m.
I believe so, though I had a Weber 32/36 on my 02 for as long as I had it. It seems like that is the go to aftermarket carb for them.
nicksta43
nicksta43 Dork
7/9/13 6:40 p.m.
Only the early car were carb, IIRC everything after 77 was mechanical fuel injection.
chrispy
chrispy New Reader
7/10/13 8:21 a.m.
It'll have Bosch CIS (k Jet). Switching to a Weber is basically swapping in a 2002 intake manifold and adding a Carter fuel pump.
cutter67
cutter67 HalfDork
7/10/13 8:31 a.m.
the price on the 320's is climbing fast. this does not seem like a bad deal. i remember sub 1k 320's were everywhere now trying to find a sub 2k is hard and many nice ones are pushing 5k now
yamaha
yamaha UberDork
7/10/13 11:08 a.m.
nicksta43 wrote: Only the early car were carb, IIRC everything after 77 was mechanical fuel injection.
78+ are EFI or carb(IIRC)
ibli2lgvtH2gU45Q66RA5jhIXKfqGgrjDzvmWN2zbcv0eS6fFtE04dLUQfREzwy9
