EvanB
SuperDork
7/30/11 2:33 p.m.
http://dayton.craigslist.org/cto/2436002923.html
ad said:
Nice Mazda RX7 1000 OBO MAJOR PRICE DROP NEEDS GONE ASAP . Oil has been change, new oil filter, new spark plugs, has a rotary engine 1.3 liters and Turbo charger. The body is in Really good condition except for one spot where there was a dent but got knocked out but never finished. The car Does start engine sounds really good the fuel pump and fuel filter need replaced and also small clutch work such as slave cylinder and master cylinder, Some brake work is probably needed. You might just be able to bleed the clutch that also might work. Its a really nice car i would love to fix it up but i dont have the time or money to do it. If you are interested email me Or call 937- three 1 two 56 64 - Darien-
It has a turbo...right...
I miss my SE. I'd be real tempted to buy this if it wasn't so far away.
stan
SuperDork
7/30/11 3:02 p.m.
I'll give him $500 and he can keep the turbo.....
No turbo in that engine bay. It is worth it though if it runs, the parts will recoup the purchase after it has been flogged at the challenge
Hey I work in Huber Heights.
wow where is he hiding that turbo at? or is it just sitting in the passenger's seat? definitely doesn't have the turbo hood though.
Here's a way better looking deal on an RX-7, also in Dayton: CL Linky
seller said:
1985 mazda rx7. limited slip rear end,5-speed trans w/good clutch,four wheel disc brakes carb rebuild in july. weber side draft carb.new starter,cap,rotor,plugs,fuel filter,fuel pimp.car has 111,347 miles. engine rebuild by Ed Bochenek only has about 12,000 miles.car is a blast to drive but needs to go.
send me a email for more pics on info.or call 9379eight59837 after 5:30,any time on weekends if i dont answer ill try to call u back.
thanks for looking
Ed Bochenek used to work for the factory Mazda racing team in the 70's and is a master with Rotarys. Highly recommend his work.
So you guys going to buy it then?
