GVX19
GVX19 Reader
7/20/11 7:42 a.m.
I need a challenge friendly Eng.
I'm ruining out of time. Do not make me use the Eng out My YUGO,please!!!!!
16vCorey
16vCorey SuperDork
7/20/11 12:02 p.m.
If you're head is good, maybe try to put together a 20/20? Using an ABA bottom end (common as dirt), the 1.8t intermediate shaft into the ABA bottom end, a 2.0L 16v timing belt tensioner, and (I think) a 157 tooth timing belt. Something like that. I may be off on a few details, but if you've got a good head you can lego the rest together.
GVX19
GVX19 Reader
7/20/11 5:57 p.m.
Okay I'm not one to point fingers. But this is all your fault. You and that Lego E36 M3 is what got me in to this mess. LOL.
When you have a min. Ill need more info on this "20/20". Thanks.
mrwillie
mrwillie Reader
7/20/11 6:07 p.m.
GVX19 wrote: Okay I'm not one to point fingers. But this is all your fault. You and that Lego E36 M3 is what got me in to this mess. LOL. When you have a min. Ill need more info on this "20/20". Thanks.
+1 -- I would like info on this also.
corytate
corytate Reader
7/20/11 6:13 p.m.
1.8t's are decent. VERY restricted by the stock turbo, but maybe you could get the holset for sale on the boards to work? with something that big though, youd have to worry about being able to move before spool lol, that thing would probably take forever to spool with a 1.8 driving it..
1.8t with a different "t" is a good idea though.
Paul_VR6
Paul_VR6 HalfDork
7/20/11 8:34 p.m.
20/20 is simple, sort of. You have to block a bunch of oil returns in the back, odd length timing belt, and you need a certain tensioner as well to get it working. I can't remember if the center intake clears a stock ABA piston and it might need to be fly cut. IMHO unless you have a head and nothing else, I'd just do a full 1.8t longblock to keep it simple. The rods from the earlier 1.8's (and 2L 16v) will fit if rebushed for the smaller wrist pin and are much stronger.
Sonic
Sonic Dork
7/20/11 8:34 p.m.
I have a parts motor that you can have for the cost of shipping from PA, or if you just want some of the parts.
It is an AWP motor from an 04 GTI 1.8t. The valves are a mess, a piece broke off of one or two and rattled around the combustion chambers, so the tops of two pistons are a mess as well. The block is good, as are the crank, cams, manifolds, etc. It is nearly complete, so just tell me what you need,
corytate
corytate Reader
7/21/11 1:06 p.m.
would a vr6 not be a viable option?
16vCorey
16vCorey SuperDork
7/21/11 1:53 p.m.
No. He's working on an Audi A4, I believe. Sounds like Sonic's stuff is the way to go, if you can put one together out of the two. Around here complete 1.8t engines are still bringing pretty high prices.
wearymicrobe
wearymicrobe HalfDork
7/21/11 2:09 p.m.
corytate wrote: 1.8t's are decent. VERY restricted by the stock turbo, but maybe you could get the holset for sale on the boards to work? with something that big though, youd have to worry about being able to move before spool lol, that thing would probably take forever to spool with a 1.8 driving it.. 1.8t with a different "t" is a good idea though.
Tons of K04's around and there are even vane swaps for the K03 that make decent power.
GVX19
GVX19 Reader
7/21/11 8:50 p.m.
Yes it problem car is an Audi A4 2001 with a AWM 1.8t Do all the 1.8's use the came crank?
Paul_VR6
Paul_VR6 HalfDork
7/21/11 9:50 p.m.
There are two "style" cranks. Aeb and atw use the same as the "old" vws but with a trigger wheel and all other codes have a chain drive for the oil pump thats not on the early crank.
GVX19
GVX19 Reader
7/26/11 8:47 p.m.
In reply to Paul_VR6:
So what your saying is that I can use the crank form any 1,8t that has a chain drive oil pump. No matter the AWM or what ever the eng is stamped?
16vCorey
16vCorey SuperDork
7/26/11 8:59 p.m.
Yep.
Paul_VR6
Paul_VR6 HalfDork
7/27/11 2:55 p.m.
Double Yep.
John Brown
John Brown SuperDork
7/28/11 5:32 p.m.
I have a 2005 Jetta GLI parts car that has REALLY foggy windows and squishy Recaro seats I might be able to separate soon.
Paul_VR6
Paul_VR6 HalfDork
7/29/11 10:13 p.m.
Want to just dry it out? I need a decent daily
John Brown
7/29/11 10:31 p.m.
After 60 hours in sewage water I am thinking that nothing will get the stank out.
GVX19
GVX19 Reader
7/31/11 1:55 p.m.
In reply to John Brown:
What!!! It cant be that bad. Can you have that eng delivered to the challenge?
Sonic, PM sent.
GVX19
GVX19 Reader
11/11/11 10:47 a.m.
16V Corey!!!!!! ?
Will an eng out of a 05 A4 work in my 01. Does it matter if it had an auto.
GVX19
GVX19 Reader
9/17/13 10:22 p.m.
Thanks guys! it only took three years but its alive! I got a crank and bearings from You Pull It for only $50. Lost it in shipping and storage. But I found it and made time to get it installed. Thanks for your help!
Paul_VR6
Paul_VR6 HalfDork
9/18/13 4:58 a.m.
Wow, good stuff!!
16vCorey
16vCorey PowerDork
9/18/13 10:05 a.m.
Nice!
xflowgolf
xflowgolf HalfDork
9/18/13 10:16 a.m.
GVX19 wrote: 16V Corey!!!!!! ? Will an eng out of a 05 A4 work in my 01. Does it matter if it had an auto.
YES!
The end of the crank is machined different, at least on the early AEB cars. The automatics have a larger bored recess in them and the pilot bearing will not fit.
I found this out the hard way rebuilding my 99.5 1.8TQM with a motor donated from an automatic.
I resolved it by having a bushing machined to make up the difference, but it was still another unforeseen delay when everyone had told me "they're all the same... blah blah blah"
7Txd2xyFWNNm5g9UZUrSmkhwT8nXfpTikwrT3wSafAZzQW4IQSzoH5ri8kgajrxy
