tripp
tripp Reader
7/9/17 7:16 p.m.
https://jacksonville.craigslist.org/cto/6195673584.html
NMNA not sure if it is a v8 the way it is written I would assume it is but the ad lists it as a 6. Could be a decent challange car if an 8.
1996 chevrolet camaro condition: good cylinders: 6 cylinders drive: rwd fuel: gas odometer: 170000 paint color: white title status: clean transmission: manual type: coupe 1996 Camaro 5 speed manual pistol grip shifter. 173k Engine has been built crank on up for nitrous but does not come with any nitrous components and has not had nitrous ran through it with me. I'm not sure what the horsepower is but it gives brand new 392 hemi challengers a run for their money in the 1/4. It has drilled and slotted rotors and ceramic brake pads and shoes. A stage 3 racing ceramic clutch and custom made one piece driveshaft instead of the crappy stock 2 piece. Fun car for a beater. I've had it for 6 years now and the only major thing that had to be replaced in that time was the clutch which I did personally. It needs tires and air filter tubing and air filter it had a cold air intake on it. It will start right up and drive with no problem but you should get the air tubing and filter. $100, screwdriver, 10 minutes, a 1/4 of a brain and that's taken care of. Tires have been good enough for me the last 6 months and are good enough to drive on for awhile but really should get new tires because the backs are 50s and you feel like you're hydro planing when they were new because of how wide they are. Exhaust from after cat needs work but I've only ran a pipe back after cat and that's how Ive always had it. I do have the manga flow exhaust and piping that came with it, yours if you want it.
mndsm
mndsm MegaDork
7/9/17 7:45 p.m.
I'm betting v6. That looks like am rs package.
Andy Neuman
Andy Neuman Dork
7/9/17 9:20 p.m.
Birthdays
iT9s8dXuBHq7WG0vViuRzs63aK2c72dECpmbrDhUpGyeQ5f5UvJjs43WqkYtLPTx
