NGTD
NGTD UltraDork
7/5/16 7:13 p.m.
I have a large number of parts left over from a couple of projects and would like to clear them out since I sold my Subaru. If you don't like the prices, make an offer. Will do package deals for more than 1 item Prices are in $CAD. I really want to clear some of this stuff out so make me an offer, chances are I won't say no:
  • 05 WRX Engine - EJ205 - Mostly complete, but the timing belt skipped. I haven't looked into what is wrong. $400
  • Complete Rad with fans - $200
  • 05 WRX ECU c/w Engine Harness - $300
  • Clutch Master Cyl, hydraulic line and slave cyl.- $200
  • Power Steering bump with lines - $200
  • Extra set of power steering lines - $50
  • Pitch Stop - $25
  • Starter (manual trans) - $75
  • Alernator - $75
  • Fuel Pump and fuel level covers - $20
  • Radiator brackets - $20
  • 02/03 Wagon tailights - $75
  • Goodridge SS Brake lines c/w clips - $75
  • ABS sensor (front) (2) - $150
  • Clock (working!) - $40
  • Grille (bottom tabs are broken but top ones are all good) - $50
  • In dash switches (fog, cruise, filler) - $25
  • Outer tie-rod end - $25
  • Complete tie-rod (inner and outer) - $50
  • Windsheild washer tank (wagon - dual pumps) - $50
  • Hatch struts - $50
  • 02/03 upper Coolant Tank - $50
  • WRX Intercooler with bypass valve - $100
  • Complete Front Wiper assembly (wiper arms, wiper motor and linkage) - $125
  • WRX Fender braces with hardware (will stiffen the front end of a regular Impreza) - $50
  • Console pieces (shifter cover and drink holder with Heated Seat switches) - $50
  • Airbox with MAF sensor (piece that goes into fender is gone) -$75
  • Instrument Cluster (304k kms) - $60
  • Bugeye Headlights - $75
  • Cruise Control Motor - $75
  • Multi-function switch (wiper, turn signal etc. for wagon) - $100
  • Shift mechanism - $40
  • Momo WRX Steering Wheel - $85
  • Stock Down Pipe (or Mid-Pipe) - $75
From an 07 Impreza 2.5i
- Throttle Body - $75
- Coil - $85
- EGR Valve - $100
pav5069
pav5069 Reader
7/5/16 7:23 p.m.
where are you located?
NGTD
NGTD UltraDork
7/5/16 10:09 p.m.
In reply to pav5069:
North Bay, ON
ZZKV9aMeIFsZrww66sRUgcji72Bin3YiLIF43tkhp0qDowenT7lq6OabirzaUEzt
