Treasure Coast Miata
Treasure Coast Miata New Reader
10/4/13 3:45 p.m.
Treasure Coast Miata Announces it's New 1990-2005 Miata Front Engine Service Kits for $153
Timing belt replacement on your Miata is one of those critical "hidden" maintenance items. Replacing your timing belt (your water pump is recommended also) at regular 60k miles is something Mazda highly recommends to keep your Miata running. This kit will supply the DIY Miata mechanic with everything they'll need to completely service the front of their Miata's engine when replacing a timing belt and water pump including the often overlooked tensioner pulleys, Cam and Front Main Seals. This kit uses high quality OEM and Gates Automotive (best aftermarket replacement brand next to OEM Mazda) parts. If you haven't changed your valve Cover Gasket and Cam Angle Sensor O-ring recently then you can add them to the kit. We insist on using an OEM Mazda Valve cover gasket and CAS O-ring because the aftermarket replacements are very poor quality, and we've had problems with them sealing on our cars in the past.
Please visit our Web Site at TreasureCoastMiata.com or you can link to the products below;
For '90 - '93 http://treasurecoastmiata.com/i-14385851-1990-1993-miata-timing-belt-water-pump-replacement-kit.html
For '94 - '00 http://treasurecoastmiata.com/i-13996806-1994-2000-miata-timing-belt-water-pump-replacement-kit.html
For '01 - '05 http://treasurecoastmiata.com/i-14386191-2001-2005-miata-timing-belt-water-pump-replacement-kit.html
Let Treasure Coast Miata be your one stop for all your used Miata parts needs
Your Used Miata Parts Super Store
Swank Force One
Swank Force One MegaDork
10/4/13 4:27 p.m.
The three links to the kits 404.
Which kit would an MSM owner buy?
10/7/13 8:08 a.m.
'99 - '00
10/8/13 9:58 a.m.
Links fixed!
IkBaXHD7qXOB1L0MIr4JFecGnNjQVZiF8JWBwFP0BVnYGYjq9hLGn5TuD5zu7URM
