I'm going to start with some analysis of the rear foil first. I used the above outline, and a version where the outline was 'filled in' and sucked them into JavaFoil to generate two sets of coordinates. I brought those both into XFoil and used the "interpolate" command to 'average' the data between them, to try and smooth out some of the 'roughness' that tends to creep in from tracing the outline with three-segment, four-node curved line segments in paint.net. This 'combined' foil was then expanded to 200 points via XFoil's PANE command.
I ran a viscous polar on it at Reynolds Number {RE} 7e5 (700,000) from AoA -5 to 20, in 0.1deg steps. Then I took the foil into the 'MDES' design menu and used its FILT command to try and smooth out some of the roughness... with limited success. Then I ran a second polar, which showed minimal (mostly in the drag curve) changes. Please keep in mind, these results are 2D, only... and don't account for GroundEffect, or 3D Wing-Plan Effect:
I used the same 'filtered' 200 point file to pull into JavaFoil, and then went through setting up the coordinates in the 'format' that JavaFoil prefers. With these JavaFoil-specific coordinates, I performed 3 Polars sweeps with JavaFoil from RE 600,000 to 1,000,000 and "-7" to "20" deg AoA. The three setups were: 2D (infinite AspectRatio, AR), AR = 5*, and AR=5 and 250%chord above the ground:
*a word on AspectRatio = (b^2) / S = ( wing span squared ) / ( wing planform area ) = ( 69.5^2 ) / ( 69.5 * 16 ) = 4.34
but, there's EndPlates... so using the linked endplate effect estimate, and guess that the endplates are 6" tall/deep: 4.34*(1+1.9(6/69.5)) = 5
**a word on Reynold's Number (RE)
this helps 'us' account for the nature of the flow (laminar regime vs. turbulent regime; or 'Low Reynolds Number' {e.g. less than ~500,000} vs. 'High Reynolds Number' {e.g. 1,000,000 and above}). Calculated by: RE = rho * V * L / mu (where I'll be using 1976 NASA standard atmosphere values for Sea Level for rho (air density) and mu (air viscosity))
RE = 0.002377 * (88) * (16/12) / (3.737e-7) = 746,000
which is reasonable to round down to 700,000 for now.
I'm not real sure what the effect of the 'unsupported' low-pressure side of the skin will have on things. The foil clearly has a pretty sizeable nose-radius... which in this case is good. Plus, the conduit isn't too far off the skin, if drag at the stagnation point 'pushes' the skin back, and the low pressure suction trying to pull the skin "down". For challenge... I'd guess it's not a big deal... especially if you shallow out the rear foil for the drag passes.
I think Cl.max of 1.75 is a reasonable estimate of this foil's capability, including 3D/Ground/Endplate Effects.
Rear Downforce, 60mph {88fps}, 1,112sqin = 0.5*0.002377*(88^2)*(7.72)*(1.75) = 124#s
Rear Drag, 60mph = 0.5*0.002377*(88^2)*(7.72)*(0.06+(0.0637*(1.75^2)) = 18#s
for ballpark sake... there's some public data for a cat-ish foil that's 70" long (9.25" chord) with 8" endplates. At 60mph and 10deg AoA it pumps out a Cl ~1.76 for 76#s of downforce, with 7#s of drag. So, you've got 2.5x the drag for 60% more downforce... mainly due to the longer chord and 'get it done' foil shape. On the other hand, it's what... $5 out of pocket?
I've been thinking about the C.G. / Aero-Balance thing I brought up back a page. I think it'll be better/easier to reference these to the 'engine side' of the firewall. So, when you get a chance: can I get a distance from the nose of the foil to the backside of the firewall. And, similar distance to the 3/4" square tube on the front main element?
edit:
I should note, when I pulled the sections and popped it into XFoil, it was estimating a maximum thickness that was 12% of the chord, at a point 20% back from the nose... or a 2" maximum thickness 3.25" back from the nose. Looking at that a bit more, with squares scaled off the front conduit...
I think I might slim this down to 11% (i.e. 1.75" thick) and give it another go. I don't think 1.5" thickness is right, though?
as for camber... the codes were evaluating it around 6%... which, eh. I'll have to dig around a bit, and see if I can get you a 'height' above the 'flat-ish' "top" skin back at the 1" square tube 'rear spar', to check against.
