Fixed a few problems this week, my 2 kid was born the day after xmas so free time has been spent getting ready for him mostly.
The regular coupe bumper came in the mail. The mailman must have filled up the entire cargo space of his caravan with this box
The bumper was scratched so the ebay seller knocked off %40 or ($74! For the non mathy folks). I just used the rustoleum as a primer as it was so cheap and sprayed over the scratches. The enamel rustoleum is self leveling so a couple of coats filled in the scratches with no sanding. It has been on the cold and humid side here lately so the paint is slow to dry. I mounted the bumper cover (with the junkyard sedans foam bumper, fender wells, and headlight mounts ) even though it could still use a sanding and another coat. The paint is a pretty good match for $25. Its a little off as there is no clear coat but from a couple feet away the average person wont catch the differences. Looks about like whatever the single stage paint the collision repair shops use.
I have been tracking down leaks with all the rain lately. Most of all leaks have come from the clogged sunroof drains, all 4 of them. I pulled the headliner and blew compressed air through the drain lines and all kinds of water and crud blasted out on the garage floor... After of course the water (a lot!) in the sunroof poured on me as I pulled the drain tubes.
I also loosened, slightly moved and re-tightened the door latches to get a better seal around the doors and a tighter shut. Slathered some white petroleum jelly along the weather striping (to somewhat renew the old weatherstrip seals). And reglued the trim strips that run along the retractable windows. They had rubber separating from the aluminum in a few spots and were letting water into the doors.
I am currently looking for a good replacement fabric for the headliner. The old waterstained tan stuff is pulled from the headliner and I am playing around with some higher end artist canvas. I am thinking about using fabric dye and a water based paint to stain the tan canvas. I might have to see what the craft stores have to offer or start cutting up some curtains or something....
The shift ball and the boot came in the mail too. The old saab style knob was glued on with some serious stuff. I had to peel off the rubber coating and turn old blue loose on the metal underneath. After copious amounts of smoke the old crusty knob slide right off.
The new honda aluminium knob was threaded instead of splined. To get it to fit I just drilled out the ball a hair tighter than the splines. Then used epoxy as extra security. There was a reverse lockout mechanism, to keep drivers from shifting 5th gear into reverse. The mechanism was annoying and getting in the way of the boot swap so it was discarded. I have missed a few 4-5th gear changes without the guard but it was worth it.
The shift boot was straight forward, it just needed stapled to a plastic frame and was hand pressed into place. The staples had to be hand bent with pliers to close. I tried a swingline style stapler but it was too weak. Then switched to a t50 stapler and bent the staple ends in with pliers. I used the end of a soft wood board as backing to the stapler.
Cut out the old resonator as well as installed the new muffler in its place. The old flange bolts were rusted into spikes. So two cuts with the saws-all and I was hoping to slip fit the new muffler in place... Wasnt that lucky. The tube diameter changed from 2.5 inch to some other larger size just before the flange. The 2.5 inch muffler needed an adaptor. I had some 3 inch tube left from another cars exhaust. So I made an adapter sector from the 3 inch stuff. First I cut about an ⅛ inch section long ways from the tube and welded it up. Then I cut four v shaped slots longways on half of the tube segment and bent/welded the "v" s so they necked down to the 2.5 inch tube.
The muffler helped bring the tone down but also helped to find leak in the exhaust in the top of the factory muffler
Last I started taking apart a few switches and cleaning the contact points with sandpaper. The power mirrors and sunroof are now operational again
