A buddy of mine who I do a little side work for dropped this off at my house and asked if i could get it running and driving (and somewhat functional) for him. Basically, he live in a lake community where everyone drives around side by sides, and he wanted something a little different. This thing is pretty rough, so not really worth restoring, but worth a little bit of effort none the less.
The first thing I did was turn the engine over by hand to make sure it wasn't locked up - it wasn't. Next thing I did toss some jumper cables on it to see if it would crank over - i did.
I broke on the old DMM and found the coil was getting power to it. After a little more testing and found the coil to be functional, so I moved on to the points.
Inside the distributor found the rotor, points, and condenser all to be new(er). The points were a tiny bit dirty, and they were not set correctly. After I cleaned up the points and got them set, I filled the carburetor bowl with gas and cranked it over. It fired right up!
So I got it running, now I need to toss on a new (smaller) belt, as it was too loose and there is no more adjustment left. I need to fix a small fuel leak (hopefully just tighten a line.)
That's kind of where I am at now.
To get it driving, I'm going to have to install some new wheel studs/lug nuts, and fix some seats.
To get it function, I need to patch up the floor pans, do a bit of rewiring, and a bunch of cleaning.
Heres the jeep in all her glory.
As you can see, it's ROUGH.
Here's the video.
http://www.youtube.com/watch?v=Fd2cZiHDvts
I can kind of like it. lol
