Streetwiseguy
Streetwiseguy SuperDork
9/19/12 10:51 p.m.
I drove a 60 Cornbinder halfton one winter. Coldest. Truck. Ever.
Gasoline
Gasoline Dork
9/24/12 7:39 p.m.
SyntheticBlinkerFluid
SyntheticBlinkerFluid UltraDork
9/24/12 9:21 p.m.
Well, well, what have we got there?
CLNSC3
CLNSC3 HalfDork
9/24/12 10:21 p.m.
Love the IH, reminds me of one I rolled around for a short while:
Looking forward to seeing this build!
-Josh
D_Howard
D_Howard Reader
9/25/12 12:45 a.m.
http://www.speedhunters.com/2012/08/the-drift-truck/
How bout this?
Gasoline
Gasoline Dork
9/25/12 11:23 a.m.
SyntheticBlinkerFluid wrote: Well, well, what have we got there?
Taking a $300 chance on a untested 2006 6.0l LS. I was hoping it was Gen IV with square port L92 heads, but it is Gen III cathedral port 317's. I will pull it apart and have a looksee.
Gasoline
Gasoline Dork
9/25/12 11:44 a.m.
I really want a little forged stroker kit. The single turbocharger I am going to use is a 88mm Comp turbo. There are many stroker kits out there in 4.00" and 4.125" stroke which would be too big. CHP has several based on a 3.90" stroke which would be around 392-396ci. (Stock 6.0l is 3.62). I would love to be able to spin it to 8,000 without worrying about it coming out the bottom. A de-stroked 377" or the 383" kits are also a consideration, but 396" has a certain magic about it.
Double click the link to make the chart bigger. http://img.docstoccdn.com/thumb/orig/22439876.png
http://www.coasthigh.com/Chevy-LS-6-4L-engine-kits-dish-top-s/13451.htm
RossD
RossD UberDork
9/25/12 1:26 p.m.
Wait. Turbo. LS 6.0 liter being stroked. Forged Internals. Awesome Old IH Pickup. In the same sentance?
Strike_Zero
Strike_Zero Dork
9/25/12 1:59 p.m.
This will be AWESOME!!
Gasoline
Gasoline Dork
9/27/12 7:49 a.m.
Neat intake runner chart:
Gasoline
Gasoline Dork
9/30/12 8:02 a.m.
AngryCorvair wrote:
SyntheticBlinkerFluid wrote: OH MY! You need to keep those hub caps! I am a huge fan of International Harvester trucks.
get those wheel centers put into a 17x9 rim so you can have good rubber *and* bitchin' caps!
Something like this? I really do like this.
chandlerGTi
chandlerGTi HalfDork
9/30/12 8:18 a.m.
Yes, that will look awesome!
9/30/12 4:40 p.m.
In reply to Gasoline:
Yes! that looks awesome.
CarKid1989
CarKid1989 SuperDork
9/30/12 7:02 p.m.
Gasoline wrote: Something like this? I really do like this.
I actually know this truck. Have checked it out in person and talked to guys who worked on it.
BUILD IT LIKE THIS. its totally bad ass
Gasoline
Gasoline Dork
10/4/12 8:02 a.m.
New LS3 heads arrived. Jegs $315.00 each delivered. I'd say that is a bargin.
Gasoline
Gasoline Dork
10/4/12 11:51 a.m.
Woody
Woody MegaDork
10/4/12 12:18 p.m.
RossD wrote: I still think there would be a market for collecting good glass out of rotten cars and refurbing them for resale.
That's a fairly good idea...
Strike_Zero
Strike_Zero Dork
10/8/12 2:59 p.m.
Gasoline wrote: New LS3 heads arrived. Jegs $315.00 each delivered. I'd say that is a bargin.
$315 per loaded LS3 head delivered???
Gasoline
Gasoline Dork
10/8/12 3:43 p.m.
I just checked again and they have gone up to $325.00 each, so $650 plus $10.99 shipping/handling. They always price match if you can find them cheaper. Anyway new price is $31 total more than I paid.
http://www.jegs.com/i/Chevrolet+Performance/809/12629063/10002/-1
I will add; the LS3 valves are too big to fit on a stock 4.8l, 5.3l or a 5.7l ls1. You need a 4.0"+ bore block. They also take 8 offset rocker arms, which are about $128.00 new.
Strike_Zero
Strike_Zero Dork
10/8/12 11:47 p.m.
Not to take away from you thread. . . but I'm thinking 6L block and pistons + 4.8L crank and rods (on the shelf)
But still . . . less than 8 Cs for loaded LS3 heads isn't bad (especially when 243 heads that need servicing go for $500)
Gasoline
Gasoline Dork
10/9/12 8:51 a.m.
Strike_Zero wrote: Not to take away from you thread. . . but I'm thinking 6L block and pistons + 4.8L crank and rods (on the shelf) But still . . . less than 8 Cs for loaded LS3 heads isn't bad (especially when 243 heads that need servicing go for $500)
Keep the ideas coming. I like the discussion. I sure have thought about a short stroke something?, but there are several threads out there that talk me out of it.
http://ls1tech.com/forums/generation-iv-internal-engine/1207599-4-8l-crank-ls2.html
http://www.ls1.com/forums/f7/your-thoughts-high-revving-ls2-160850/
I want to really spin it without worrying about stock rods and pistons, crankshaft?. If it was a 4.8l or 5.3l (nearly free here in Atlanta) I would not worry at all. But this is a good foundation for a "good" LS big cubic inch motor. I also have enough heads and intake.
For $2k I can buy a complete forged rotating assembly, great rod bolts, bearings, and rings. ARP mains are another $160. Billet main caps are overkill, but add another $350.00 and $500.00 for machining. That is under $3k for a reliable, bulletproof block. That is the way I am leaning......mid size stroker, 8,000 rpmish.
LUNATI STROKER KIT
10/11/12 7:38 a.m.
oldopelguy
oldopelguy Dork
10/21/12 6:58 p.m.
I want one of those intakes so badly, to use as a base for a 6-71 blower. Plenty of height under that hood.....
ultraclyde
ultraclyde Dork
10/22/12 1:34 p.m.
Gas, I know you're local to me, where on earth did you find that truck? That's fantastic! And the idea of a big inch turbo small block makes me all kinds of happy, but poor Vanette looks a little sad in the background...
Gasoline
Gasoline Dork
10/24/12 8:20 a.m.
In reply to ultraclyde:
I spend too much time on Craigslist. It just popped up for sale in Canton GA. I called within a few minutes of it being posted and was trailering it home in the rain a few hours later.
Vanette is coming along slowly. I keep going back and forth about what direction to build it. I think about using it (Vanette) to pull the car trailer and doing away with truck.
I have the 300 EFI 6 ready to go in it with a ZF 5 speed, but on Craigslist there is a guy with a Ford 401 inline 6 turbo diesel and Allison transmission out of a Ryder truck. That would be pretty sweet.
I have a turbocharger that would work with the 300 gas burner, but the wiring harness is Speed Density. From what I have read the guys that added a turbo add bigger injectors up from the 12lb injectors (I never knew injectors were made that small) to the SD system have constant driving issues. I think that the California 300 trucks/cars were Mass Air and all 1996 300's were Mass Air. That was the last year for the 300?. I am hoping I run up on a 1996 Mass Air donor
Then the next decision with the Vanette is to lift it a little bit and add a 1979 Dana 60 4X4 axle up front or bag and drop it.
What to do??? If I was smart I would get off my ass and throw the 300 in there, ZF 5 speed, divorced Ford NP205 and 4X4 dana 60. I have those parts sitting ready to go.
401 Ford turbo diesel....
IwcjbtNUxCH0OkwYDSs5g7SdqcgNEMXiPciPHhXto5SNktJ3MyeeDmyYKM9z4Kq9
