6 7 8
Ben_Modified
Ben_Modified HalfDork
11/3/18 7:47 p.m.
Work continues on the Hot Rod Hijet plus a hard launch
https://www.youtube.com/watch?v=6EB8xz2V7qw
Pete Gossett
Pete Gossett MegaDork
11/3/18 8:19 p.m.
In reply to Ben_Modified :
You know Ben, as you get more of these awesome creations on the road, I think your next project should be an awesome hotrod hauler, so you could drag 3 or 4 to a show all together - plus the hauler would be awesome its self!
Ben_Modified
11/3/18 10:01 p.m.
I am chipping away at it!
Ben_Modified
11/16/18 7:43 a.m.
A Moroso re-curve kit should arrive today. The mechanical advance on the distributor is maxing out at only 20 btdc  #WheelieQuest.  My friend with the Turbo LS powered Datsun wagon stopped by with his "normal" size service bed truck.
https://photos.google.com/share/AF1QipN7CtcEXMVMZhcYrv0yMexhpVLEDHjB5kDegqsp-cPXoO31ug4Ic39zLfP3P_pr9A/photo/AF1QipNH2Y6Fpj2mXt-IWkaU0OgVp4tZMnJooSw6fkUd?key=MEJtQ2xsOGdiS0xLTVVwZy1UV2RPcjhEU2VIRG5B
Ben_Modified
9/7/19 4:12 p.m.
Start to finish.....no paint, of course.
Pete Gossett
9/7/19 7:24 p.m.
Awesome!
Ben_Modified
9/8/19 4:07 a.m.
In reply to Pete Gossett :
Thanks!
GIRTHQUAKE
GIRTHQUAKE Reader
9/8/19 1:32 p.m.
That's damn awesome- are you going to use it as a tool carrier too, or just some wild thing you made?
Ben_Modified
9/9/19 9:30 a.m.
Thanks!  I do use it as a truck whenever possible!
Ben_Modified
3/19/21 11:48 a.m.
Well, I have decided to go back to the small (21") wheels and tires.
I will regain the sleeper look, be able, once again, to fit in the 52" wide golf cart spots in my apt complex and it will accelerate even better!
I have already lifted the drivetrain in the frame as much as I can to gain acceptable ground clearance.  The radiator is at a local shop for a few mods.  Still needs to fill in the larger than needed wheel wells.  Started with rough paper templates and a few crappy manipulated photos.
And this is what happens when you get your angle grinder too close to your shifter cable
Ben_Modified
3/19/21 7:24 p.m.
Air filter reconfigured.
With heat shield
Shifter reinstalled with new longer shift cable for better routing
Ben_Modified
4/4/21 7:08 p.m.
The modified radiator is done and back in the truck
Started filling in the wheel openings on the bed. I have a few  odds and ends to complete before I can take it for  an extended drive, but I did take it down the street and it is really quick!
And for something completely random... here is a photo of a section of the Golden Rey Car Carrier which overturned last year, freshly cut from the hull, on its way to Louisiana for scrap.
4/5/21 9:01 a.m.
Wow, that's a cool pic!
Ben_Modified
5/15/21 6:51 p.m.
Working on some steel flares
Ben_Modified
5/20/21 4:24 p.m.
Flare progress.  Still need to shape the lip on each a bit more.
Ben_Modified
9/3/21 12:12 p.m.
I changed up the wheel/tire combo.  Slightly taller and quite a lot wider.  Different offset on the fronts to improve turning radius.  Also, removed the front axle, cut off the spring perches, replaced with new ones and welded on with a much improved caster angle. Also new front springs to provide more than 1" of total suspension travel.  I expect the springs to settle a bit as I don't want to be forced to wear a flat bill cap....or.....I contend that it is a gasser and not a southern squat
6 7 8
JvC62UuUAnUDIGMNnQmBS5j5gfyIveLXHhdJ7SbwbM4xgMHxWiejo5MGHreCOpDr
