NOHOME MegaDork
7/17/20 11:52 a.m.
In reply to java230 :
I think mine was 2.2 or somesuch.
And yeah, if the hose has a lot of ballooning, that will mess with the whole game. I did not have that problem, just line restriction.
The beauty of the high build stage is that you cant berkeley up. 90% is going to look amazing and there is nothing stopping you from fixing the bits that don't make you happy before you do the final topcoat ( epoxy in your case).
java230
java230 UberDork
7/17/20 11:56 a.m.
In reply to NOHOME :
Yeah it sucked. I am just going to do a whole new air system. I need to. Will all be 3/4" to the hose connections. The reel is 3/8 and a have a 1/2" hose.
I am debating on 2 or 2.2mm, I will be drilling the fuild cap on the HF gun. 5/64= just under 2mm. 3/32 is really close to 2.2
And yes, I can sand most of the screw up back out :D
Dusterbd13-michael (Forum Supporter)
Dusterbd13-michael (Forum Supporter) MegaDork
7/19/20 6:42 p.m.
java230
java230 UberDork
7/19/20 7:58 p.m.
In reply to Dusterbd13-michael (Forum Supporter) :
Thanks!! I am hoping I don't need anything at this point.
java230
java230 UberDork
7/20/20 11:15 a.m.
Started working on re-piping the air. Didn't get far as I forgot the tool for the fittings.....
Here is the fun part. Its a leftover from a past project that has been kicking around the shop. Its a drain heat recovery pipe, but I think it will work great as a cooling section. Its 40lbs of copper. I have seen lots of manifolds build onto the wall after the compressor in air builds, this is kinda just one wrapped up in a big pipe. 3/4" copper slits into 4 3/8" ish pieces wrapped around a 3" tube. I am replubing it all in 3/4" which I am finding is probably crazy overkill, because I have to neck down for the quick connects, but whatever.... :D
Ran some pipes around the attic, but its flopping as I didn't have the right parts....
Mezzanine
Mezzanine Dork
7/20/20 1:05 p.m.
Wow, that's one expensive hunk of copper to have kicking around in the shop! Will you force some air down the drain portion to increase heat transfer?
java230
java230 UberDork
7/20/20 1:09 p.m.
In reply to Mezzanine :
Yeah it is..... Long story, but the 6' one didn't fit in the hole.... Shorter was ordered and this wasn't returnable... So its getting put to use! I did have a thought of a computer fan, but I will see how hot it really gets. I left it down from the ceiling a bit, so there could be some convection?
java230
java230 UberDork
7/22/20 9:47 a.m.
Got 15 mins yesterday.
Line coming from the compressor outisde. It will have a low point drain there also.
Adapters sweated onto the heat exchanger.
First of many fittings. I may need a drain there too. Clear pip so we can find out though. And yes I realize this isn't normal air line pipe..... But I think it will be fine. Time will tell.
java230
java230 UberDork
7/29/20 12:14 p.m.
No work on the car, but work on the air system happened!
Leader and drain point for the compressor. 3/4" might have been overkill blush
Drain fitting at the cooler pipe. Looking at the "filter/water trap" I think the pipe will probably get most of the water condensed back out.... so I bypassed the filter for the line running to the hose reel on the other side of the garage. So I have the option of running thru both or just using the hose reel.
All plumbed up. kinda.... I ran out of pipe. And need a few more fittings.... I burned thru 60' of pipe in my little garage already!
java230
java230 UberDork
7/29/20 9:15 p.m.
Well berk me for trying to clean the water trap... The seal had swelled and it's leaking now.... Ugh. Put rtv one it. Wish me luck
Honsch
Honsch New Reader
7/29/20 10:11 p.m.
In the future, the next time you part out a car with air conditioning steal the condenser.
They're fantastic aftercoolers for air compressors.  The working pressure for the one I grabbed out a Golf is 600psi.
java230
java230 UberDork
7/29/20 10:24 p.m.
In reply to Honsch :
Is that the bit in the dash or up front? I may have a full RV AC unit next to the garage.... But I Think the power pipe will work pretty well
TurnerX19
TurnerX19 SuperDork
7/29/20 10:30 p.m.
Condenser is in front, evaporater is in cockpit.
ClemSparks
ClemSparks UltimaDork
7/30/20 6:48 a.m.
This is kinda like telling the guy with a Ferrari to shop for a Corvette.  That fabulous copper art looks great for the job.  Looks like the kind of thing most of us would never spring for due to cost (I assume).
java230
java230 UberDork
7/30/20 7:15 a.m.
In reply to ClemSparks :
Yeah not inexpensive.... Iirc it was 950$ ish....
And I do have the condenser from the IH still if needed.
java230
java230 UberDork
7/30/20 7:26 a.m.
I'll take suggestions for a decent inexpensive water separator and filter.....my hopes are not high for this one.
7/30/20 7:37 a.m.
I have the harbor freight one. Its ok so far.
java230
java230 UberDork
7/30/20 7:41 a.m.
This one is HF also, but 25 or more years old....
Honsch
Honsch New Reader
7/30/20 1:45 p.m.
ClemSparks said: This is kinda like telling the guy with a Ferrari to shop for a Corvette. That fabulous copper art looks great for the job. Looks like the kind of thing most of us would never spring for due to cost (I assume).
His bit of copper awesomeness has a lot of thermal mass but low surface area. Heavy continuous use will get it hot.
java230
java230 UberDork
7/30/20 4:54 p.m.
Tiny leak at the filter.... New one ordered
java230
java230 UberDork
8/2/20 6:34 p.m.
OK after a two week(??) sidetrack of the air system, its done. 3/4" line everywhere. Reg on back wall, hose reel with full pressure up front.
1
This fitting failing started this whole ordeal.... Whole system leaked down 100psi since Thursday. I may chase that.... I think its the drain on the compressor.
Sanded the problem spot on the fender. I think its still got a little wave in it, but I'm calling it good enough for now.
java230
java230 UberDork
8/4/20 8:02 a.m.
Yay back to sanding! Got the whole roof scuffed, most of the window frames, the drivers rocker. Need to hit the channels/curves still, ran out of scotchbrite
Hung some more plastci and set up my paint mix table.
Then got to making my HF Purple gun have a bigger orifice.
Blow it all apart, if the brass air "spreader" comes off, it has an internal 10mm allen key.
Here you can see how its barely seating on the tip of the needle. This is what lets us get away with this.
Break out A 5/64 bit, and drill the orifice larger. This is 1.98mm. Dont go bigger. The nozzle does not have much more meat left. Any larger and it will blow the sides out.
After drilling.
Reassemble and it still seals up fine.
Now if I can get this dining table out of here......
java230
java230 UberDork
8/11/20 2:23 p.m.
Took a few minutes yesterday to work on heater hoses.
Nipples are not terrible.
Routing is a little funky, but should work fine.
Mezzanine
Mezzanine Dork
8/11/20 2:41 p.m.
I'm reading this trying to understand how heater hoses have anything to do with painting...
angeldevil
java230
java230 UberDork
8/11/20 2:44 p.m.
Yeah Yeah..... I need to back the car out of the garage to clean under it..... And paint takes a day off....
h2VcrIgvAWc6fI5MZdOa6jJTaqJlQNnpUBiAWtO0kr8kFzMKCNEQXV16MHn1Oc6C
