sevenracer said:"also, i noticed this wear on the rear stat gear bearing. im not terribly concerned, will definitely continue to run this motor. do any rotary experts care to weigh in? gear is oriented as one would see it while looking at the flywheeel."
In reply to wcn2018 :
Copper showing at the puzzle joint for the bearing is normal.
yeah thats normal, just regular wear and tear nothing detrimental to be afraid of.
I could not get the t3 arms to easily align for this new axle, so I installed the stock upper arms back in using poly bushings. These are the ones that I had burned out earlier to use poly bushings in, before I decided that was an annoying mess and bought the t3 arms. Now I am coming back to them because they have at least some compliance compared to the t3 arms.
I am confirmed moving in mid February, so i will need to cut off working on this car end of January. Before then, just a few things remain:
- fabricate poly transmission mount
- reinstall transmission
- test flywheel balance, reinstall old one if its terrible.
- actually refill the rear end with oil this time.
- simultaneously, do heads on the van (moving vehicle! exhaust valve on cyl 6 is burned)
Poly mounts are bad for the transmission, it twists the case and causes it to leak at best and cracks the trans crossmember at worst. Usually though they just rip apart.
All the trans mount does is hold the end of the trans vertically and keep the trans aligned side to side. The engine mounts do 100% of the work of controlling engine/trans roll, which is the major force on the drivetrain because the engine is torquing against the driveshaft. The engine and trans mounts can be thought of as a triangle as far as load points are concerned.
Dang this poor guy can't catch a break, making all the wrong decisions and being corrected in real time lol
Little something im working on
the rust spot my girlfriend has affectionately named "the butthole" is no more
will get into detail on my process later. still need to paint it too
when i first bought this car i covered the hole up with a piece of flex tape just so i wouldnt leak. its been a year or more and i finally got to filling it in. the red piece is a patch cut off a '81. was able to make patches for the main hole and rusted areas of the weather seal lip with it.
the rot comes from this weird foam stuff mazda sprayed on the core support that holds the latch mechanism. its spot welded to several panels in the hatch area. it seems they had two raised spots that didnt touch the panels but were close enough they were worried about vibration? anyway this stuff decays, gets wet, and i think had direct contact to the metal without primer. rot city. it created the main hole and serious pitting on the other side. i removed the core support for access on this job. ill be welding it back in today.
i started by filling in rotted sections of the lip to get a hang of it, since they are covered by the hatch if i messed up a bit it wouldnt matter as much. there were several spots like this. 4 or 5.
tig is perfect for this. more pen with less heat, add filler as you feel its needed. no spatter. back off on the heat as youd like. all great things on thin sheet metal.
with those in, i got to work on the main patch. i cut out all rust roughly with an angle grinder, and then cleaned up the edges with a carbide bit then belt file to make straighter edges.
using masking tape and backlight, i traced the form for the patch, and used geometry marks to transfer it onto the donor piece
then the patch was rough cut and shaped until it fit snugly, tacked, and welded. it only took a tiny bit of bending to match the curve on this section. i used magnets to hold it in place while tacking
a die grinder with roloc pads flattened everything out. i went a little heavy on the heat on the left side of the patch. that got quite warped. a hammer and dolly got most of it out, but bondo exists for a reason. ill be doing 2k primer first, then bondo, then primer again. no paint match this time. the whole car has roached paint anyway and the primer is black.
you might wonder why i didnt do a square patch. the donor piece is from an '82 and i realized after getting it that the hand groove for the hatch has a different stamping. the u shaped bend has the same lines, but the lines inside the valley do not match up. if i cut a square patch i would have had to rectify that. would probably have taken hours with a hammer. i elected for a round patch only where it was needed instead.
And its done. bondo is a very theraputic experience. especially after 2 straight days of patching and grinding metal. bondo shaves like butter in comparison!
first layer of 2k on bare metal
bondo on and sanded
more 2k on top
new garage downtown is much smaller. i have a large basement space to use as a shop, but room for the car itself has greatly decreased.
im gonna work on some body panels, carbon hood, and maybe a rack and pinion conversion as top priorities. a buddy has an einstar scanner that i hope to go use to help with that last one at some point. otherwise, ill just have to actually drive the car this summer (unbelievable!).
Wow, your car reminds me a lot of mine, just further along. Year out of college picked up my 82 in 2021, got the same rust butthole on the rear, even went to the same Binford wrecking yard and pulled the dash pad out of the same car you got your rear axle from and have just started autocrossing it recently. Still stock suspension for me at the moment, but looking forward to upgrading and following your car's progress as well.
In reply to chirmstream :
What a coincidence. let me know if youre ever doing an autox at evergreen im always the only fb haha.
I took the car out for autox on memorial day again. Was late at tech and they mislabelled me as a datsun.
out of 92 cars, the lsd was definitely helping in corners. but oh man, that steering. its some crappy steering. i think i counted hand over hand 3 times for a single hairpin once.
i could definitely still feel the occasional 1 wheel peel. i guess that means im overwhelming the lsd? it definitely takes more to lose it and it regains grip faster, so im happy its there. i dont know if the discs are helping at all on course. the drums were strong enough to lock up and i dont think the course was long enough to fade the drums.
or maybe it is. but they definitely help on the street.
i noticed also a leak from the oil cooler. that really sucks. and the radiator blows coolant from the cap when the car is really pushed. used 79-80 coolers are stupid expensive or nonexistant, so ill probably install some aftermarket thing at the same time as an aluminum radiator. that way i can do a little fab and make them fit together in a relatively stock position. already have the AN oil hoses from racingbeat anyway. im also thinking of going to efan at same time.
wcn2018 said:I took the car out for autox on memorial day again. Was late at tech and they mislabelled me as a datsun.
Can't you just step up to the later (non beehive) oil cooler? I don't think many aftermarket oil coolers have enough capacity.
I would keep it as a mechanical fan. The electric ones don't usually pull enough air unless you get a monster that then taxes the tiny electrical system of these cars.
Yo: @Pete! You have more direct 1st gen experience than I do!
Not an extremely exciting update, but the alternator died and put me through 3 costco battery warranties before i figured it out. it was drawing either 2A or 200mA at rest, cant tell bc my multimeter sucks doo doo.
i swapped on an fc alty per a thread i think on ausrotary but i cannot find it. i do have this diagram i screenshotted:
I decided not to use an fc fuse box since those arent exactly lying around everywhere. i used a blue sea systems box instead, model 7725. has 4 ATX and 3 MIDI wired to a common bus. those MIDI fuses mean the thing is rated to handle a total current well above what this car will need. I have the alternator backfeed on one MIDI fuse at 80A, the original ignition hot line on a 60A midi, and the headlights and retractors on 20A ATX. this gives me one more MIDI and two ATX for future expansion, perhaps for audio and some foglights.
I had to fashion up a bracket. normally id use sendcutsend but i wanted it done fast so i used a piece of an old oil pan off an SBC im currently refreshing. this was done with the power of cardboard. kleenex, specifically.
i reinforced it by welding on some keystock. added some standoffs with some old nuts and washers. this is so ugly i refuse to post it online but luckily it will not be seen under the fusebox.
it sits where the old fusible links sat. i tied right into the old harness for ease of install. soldering outside in the cold sucks! this was a surprisingly longwinded one; i kept not having the components i needed, and had to find new hardware stores that actually have good selection of wire and terminals. most of this was acquired at vetco; the last remaining radioshack type store in the greater seattle area. i think I totalled over $400 for the materials all inclusive, oh well at least my car works again.
Hey, check out this cool spider i found!
one thing i forgot to mention; the fc alty should bolt right up and the connector for the voltage regulator is even the same. its uprated by 10 or 20A i dont remember. I had to mess with the spacer though. i actually used a fat stack of washers, but you could just grind down the original spacer. ill probably do that at some point.
The FC alternator bolts up but if you use an S5 alternator, the internal circuitry is different/not immediately compatible with the SA/FB wiring and you need to splice in a diode so the sense wire (I think) doesn't see ground with the ignition off. Otherwise it will work but there will be a parasitic drain that will kill the battery after a week or so.
I found that an older Subaru alternator bolts up with the Subaru pivot bolt (8mm vs Mazda 10mm) and plugs right in. I think the one I used was 65a but mainly it was in my parts stash and therefore free. What's amazing is the Mazda alternator is Mitsubishi and the Subaru is Hitachi, I wonder if there was some sort of JIS standard for alternators in the 1980s for that to work.
Even with a limited slip you will get some inside wheel spin if you accelerate too early, the rear suspension does not like to articulate and it gets worse with lowering, since lowering makes the articulation worse and also shortens the roll couple a lot, making the suspension effectively a lot stiffer. Run the gooshiest rear suspension bushings you can (new links if available, since 50 year old rubber is really hard in comparison) and maybe stiffer front suspension and/or swap the 18mm rear bar for a 15mm from an FB, or run none at all.
Racing Beat lowering springs for 1st gens are quite a bit *softer* than stock to combat this.
The downside to softening the rear is that the suspension will still bind, but now it will be a lot less progressive and more snap-spinny. This is why SAs used such a large bar and a fairly high stock ride height, they oversteered but it was very progressive and controllable.
On my '81, I experimented with adding some clearance voids to the upper links to both allow some fore-aft compliance to cut down on the binding, and also I did it in such a way that made the effective pivot points more parallel to the lower links. It was a huge improvement, enough so that I'm thinking about adding some negative camber to the front now that the rear can work a little better.
