YoloRX7
YoloRX7 New Reader
11/21/15 2:49 p.m.
Happy to see another first Gen 7 in the forum. Best of luck getting it running.
Fitzauto
Fitzauto HalfDork
11/25/15 12:41 p.m.
Any hints on sealing freeze plugs in the motor? Got one that is leaking even after replacement.
Fitzauto
Fitzauto HalfDork
1/12/16 7:11 p.m.
New carb! Sorta. Its leaking from accel pump so woo gotta find an NLA gasket for a Dellorto DHLA 48.
Dusterbd13
Dusterbd13 UberDork
1/12/16 7:30 p.m.
Is it simple enough that you can make it from a roll of gasket material?
Fitzauto
Fitzauto HalfDork
1/13/16 12:56 p.m.
In reply to Dusterbd13:
Thats the plan.
Fitzauto
Fitzauto HalfDork
3/21/16 4:46 p.m.
Well the damn thing decoded to be broken.
Acme Lab Rat
Acme Lab Rat Reader
3/22/16 10:59 a.m.
Which damn thing? Also, in re: keeping freeze plugs in the motor, you can always tap holes on either side, then bolt a plate over said freeze plug (trick I used on my red block Volvo).
Fitzauto
Fitzauto HalfDork
3/23/16 1:48 p.m.
In reply to Acme Lab Rat:
At least two seals are gone for sure.
Acme Lab Rat
Acme Lab Rat Reader
3/23/16 2:02 p.m.
Apex seals? Oh crap. Well, time for a 13B swap!
Fitzauto
Fitzauto HalfDork
5/30/16 7:45 p.m.
Welp SWMBO decided to go with a 13b turbo swap along with an FC subframe. Now we gotta find a motor. Already have the subframe.
U8TM8998kW5zDM4C3oyYcKhdAUSxK6LT9j8tejRQfmQpwkUWAYn1Mp90e1VeGIFV
