10 11 12
Dusterbd13
Dusterbd13 UltraDork
7/16/15 9:31 a.m.
define interesting trades.
restored vintage power tools and beer?
JamesMcD
JamesMcD Dork
7/17/15 10:07 a.m.
I'll trade you my FD for your car plus $10,000.
dansxr2
dansxr2 Dork
12/1/15 4:07 p.m.
 photo IMG_20151026_193214595_zpsx6cv3euh.jpg photo IMG_20151027_030746_zpsyxpjqdn3.jpg I haven't posted any updates recently sadly. I had ran into a few issues and am happy to report they are resolved. I need to get new tires, but may swap to 16" or 17" in the springs. Anyway, when I assembled the fresh engine, I used a cheap timing belt that my brother gave me with a nearly complete rebuild kit from the '89 Probe GT I also have reacquired recently. After assembly the engine had oil leaks from both sides of head. I believe the no name belt let go either from oil or brake cleaner splashing on it. The #4 sparkplug hole had an insert and it developed a crack be the plugs hole, to the insert. Reassembled and it runs very well. I believe the T3/T04E .57 Trim .60coldside.63Hotside is a little oversized. The 260 reground cam shifts the power band about 1k higher, so now the Turbo hits 12-psi (via a MBC) at 4,000rpm. If I swap to a smaller straight T3 it should respond and have a much broader power band. Other than a respray over the coming winter I'm really happy with the way the car is progressing. A professional tune will come soon.
Ironsides
Ironsides New Reader
12/2/15 8:00 a.m.
Progress is looking great! What color are you going to go with for the respray?
dansxr2
dansxr2 Dork
12/2/15 9:09 a.m.
I believe I'm gonna go back to the Iridescent Green/Blue/Purple. I have 2 Gallon of it, as well as 2 Gallon of Red/Purple/Blue as well that I got super cheap for the KLZE car I had, but reluctantly sold to fund an MR2 Turbo. I apparently didn't put enough of the intermediate (color) over the black, so it should look much better and vivid once repainted. This is the puc that sold me on going away from Ultra Bright White with Cosmic Blue Pearl.  photo chameleon-lava350z.jpg.cf_zpsb9ee49yd.jpg photo 20130411_134046_zpssgmqgglz.jpg Can't wait to see it redone!
dansxr2
dansxr2 Dork
1/14/16 9:02 p.m.
Going to get Dyno Tuned Jan 26th. Should put down decent numbers!
Vigo PowerDork
1/16/16 8:42 p.m.
Good to hear about the cam. My feeling after driving my stock f2t car for a while was that that was something it could really benefit from.
dansxr2
dansxr2 Dork
1/17/16 4:37 p.m.
The stock cam makes the feel like its hitting a wall around 4500rpm not it pulls like crazy!!!
4cylndrfury
4cylndrfury MegaDork
1/18/16 7:35 p.m.
Nice...
dansxr2
dansxr2 Dork
2/12/16 10:27 a.m.
Well my Dyno day got delayed a few days, but February 5th we got there after snowmageddon. Initial output was 209whp/217trq at 11psi. My tuner is a hardcore Honda guy, not very familiar with Megasquirt but very familiar with tuning on Neptune/AEM/Haltech so no problem tuning my MegaSquirt DIYPnP. He redid my Timing Map & VE Table, and we did a few couple pulls on the Dyno. We discovered the spark was blowing out up top so we swapped plugs to BKR7E's gapped down and bam, no more blowout. Turning the boost up to 17psi netted 232whp/223wtrq. Knowing something wasn't right I discovered a leaking intake manifold gasket so we stopped at that. I have fixed that leak and it runs much better! Hoping to take her back again to give it another go. But I' . Betting its over 300whp now. Once my photo bucket account is back up, I'll upload pics/video.
4cylndrfury
2/12/16 1:22 p.m.
WOW!!! thats a really impressive bump coming from the tune. Are you getting to the point that the clutch is going to begin to be a weak link?
dansxr2
dansxr2 Dork
2/12/16 9:40 p.m.
https://flic.kr/p/CZEhLJ Strapped down and ready to go.
https://flic.kr/p/DXaG86 First Base line pull.
Base line https://flic.kr/p/Dv3H7q
Final Dyno#'s https://flic.kr/p/DLJW5m
Lesley
Lesley PowerDork
2/24/16 11:11 p.m.
Great thread, love that there's another GRMer building an MX-3.
Vigo PowerDork
2/25/16 7:47 p.m.
According to that final graph your camshaft is amazing and i'll be needing an exact copy.
JamesMcD
JamesMcD Dork
2/25/16 8:01 p.m.
Ditto
dansxr2
dansxr2 Dork
2/27/16 8:47 a.m.
Contact Jon Bodwell of Delta Camshafts, be sure to tell him Daniel with the F2T MX-3 referred you ;-) Its a 260 regrind. Makes great power with those Dual Valvesprings!!!
dansxr2
dansxr2 Dork
3/16/16 5:26 a.m.
Well the first set of Non-Turbo pistons have met there demise... photo IMG_20151026_214412106_zpsbaktnwjr.jpg  photo IMG_20160222_203733_zpsv5czvfaa.jpg
3 decided to let go, I'm suspecting ringlands. After the MR2 is finished, I'll fix this gem.
dansxr2
dansxr2 Dork
8/11/16 4:55 a.m.
 photo IMG_20160804_165104096_zpsfeex61sp.jpg Brown Santa came! NOS Ford head gasket set, bearings, conversion gaskets. The cast Non-Turbo Pistons didn't like 20psi. So I'm refreshing the old stock bore F2T block that came in the car and back to the 7.8:1 hypereutectic Pistons. Pics coming shortly.
dansxr2
dansxr2 Dork
9/23/16 5:53 p.m.
Pulled my old engine to refresh, and see this E36 M3...  photo received_10153732347121333_zpsox5nhp9a.jpeg I'm sourcing a replacement Piston and beginning reassembly of the bottomend.
Vigo PowerDork
9/24/16 11:36 a.m.
The only way i've run 20psi on the non-turbo pistons in my 90 Caravan is with race gas. I'm sure they would break on pump. I'm going to run race gas AND nitrous on them next time down the track.
10 11 12
8mAPmq65j4y2FKg3VGdMjZMHzZCV29kGQJm0pulpDOaL0MaOEuGczv68igDBn7Lq
