Good news! The car made it through an entire race and a heat of another, and is still running great. And by great, I mean I'm really excited about it's performance.
Last weekend, I went to Roaring Knob Motorsport Complex to "test" the car. It was an actual race, but the track has (sadly) been struggling with car count this year. I have never been there, and it's much smaller than the tracks I'm used to. Their rules are also much more open to modification in the 4 cylinder class, so most of the cars that race there are nicely prepared. They also allow you to use different size tires.
I made an educated guess on tire sizes, opting for a 205/50-16 Federal 595 on the RF, 205/55-16 RR, and 205/45-16 on the left side. The 205/45-16s I had were old and almost bald, but gave me the front stagger I wanted to help pull me through the turns on the tighter track. Based on the right front tire, this would give me a top speed in 3rd gear of 87.51 MPH at the 6500 RPM rev limit. According to Subaru, my engine makes peak torque at 4400 RPM and peak HP at 5600, which puts my speeds at 59.24 MPH and 75.4 MPH respectively. I didn't have much to go on, but a friend who has raced there said I should gear my car for "maybe 75?", so that's what I went for.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/07/01/1561992672_20190623_121023_mmthumb.jpg)
I also made some aesthetic changes to the car with a flat black RS hood and a hatch and roof spoiler.
I started last in my heat of 4 cars, but was in P1 by the first turn, and continued to pull the field for the 6 laps of the heat. I quickly noticed that having one good tire on the right front of the car wasn't the best setup, and the car was really loose. Still, it seemed to run great, and I think the gearing was spot on, as I was turning about 6000 RPM before I got into the brakes for the turns.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/07/01/1561992839_20190624_082413_mmthumb.jpg)
These were probably a good tire - 6 years and 8k miles ago.
They inverted the field for the 9 car feature race, so I started in the middle row, inside line. I settled into P4 pretty quickly, but struggled to find a way around the 3rd place car. I finally got around him with 2 laps left, and quickly caught P2, but didn't get around him.
This past weekend I went back to Cumberland. I tried out some new 205/55-16 tires, which should have gotten me close to the gearing I wanted. Somehow, I was way off. The car was into rev limiter about halfway down the front straight, meaning I was above the engine's HP / TQ range for the majority of the lap. Regardless, the car handled well and still outran some fast Cavaliers that have won at that track before. I started in last place, P9 for the heat race, and worked my way up to 2nd. I tried running 4th gear on the last lap, just to see how much it lowered the RPMs, but I was only turning about 3800 RPM when I got in the throttle in the turns.
The feature was canceled due to rain, which was okay with me because my gearing was so far off.
So I'm doing some maths this morning to try to find out a good tire size. Here's the gear chart for my trans:
TY754VA1AA 3.545 1.947 1.366 0.972 0.780 FD 3.900
It looks like my 4th is an overdrive and is really far off 3rd, which ruined my thoughts of running a smaller wheel / tire and using 4th gear.
I have this trans available to me for free, from an 06-07 NA Impreza:
TY754CV7AA 3.545 2.062 1.448 1.088 0.780 FD 3.900
BUT, it seems like the best trans I could run at Cumberland with a reasonable tire size is any 5 speed from a ~99+ Forester, Legacy, or RS, which has the same gearset as the 06-07 Impreza, but with a 4.11 final drive. I could pair it with a 205/50-16, which is a common performance tire size, and be geared to run just under 100 MPH at the 6500 RPM limiter.
I think the car should be a top performer with the gearing figured out. I'm ready to win some races, but I guess this is all part of developing a new car.
