28 29 30
dyintorace
dyintorace UltimaDork
1/22/25 9:56 p.m.
The interior changes look great!
Cotton
Cotton PowerDork
1/22/25 10:29 p.m.
I've always wanted one of these,  but never managed to pull the trigger.  The newest 911 I have owned was a 993 targa.  I'd be interested in this one is you ever decided to sell.  You've done a lot of great work to it.
docwyte
docwyte UltimaDork
1/23/25 8:38 a.m.
Thanks guys, the interior trim has made a substantial change in how it looks.  It's not a featureless black hole now.
This is one of the few cars I've had that I'm really happy with, I honestly don't know what would replace it that I could afford.  I'd love a 997 GT3RS, but that would cost $100k more than my car...
t44tq
t44tq New Reader
2/4/25 7:04 p.m.
In reply to docwyte :
The S54 clown shoe is a forever car for me. It's too unique and quirky that it's not really replaceable.
I've driven a stock 996 turbo and they are nothing like the shoe. You have to rev out the shoe to get power. Also, not very torquey. Not bad, but nothing like a forced induction engine. Also, the shoe can be very twitchy when you push it. I would not turn off DSC on the street- it's done some unexpected things here and there that DSC saved me from a possible crash.
The E63 wagon is a beast. Very fast, fairly comfy, much more modern if you're looking at a W213. Does a better job as a GT than a 996 turbo, but sucks at the sports car thing. The 996 can be sharpened up like you've done. Virtually zero aftermarket for Benz other than power mods.
docwyte
docwyte UltimaDork
2/7/25 4:11 p.m.
In reply to t44tq :
I passed on the clown shoe.  It's a cool car, but just not the same as my Turbo.  I'd love an E63 AMG as my daily and keep the turbo as the fun car but there's a lack of money there, haha.  I'll likely get a 2013-2017 Cayenne turbo as my next DD, as long as I can find one with the options, mileage and price I want.
Anyways, I'd knocked the burs down on the turbo oil reservoirs and it definitely helped, the drivers side turbo was basically clean, but the passenger side turbo still had an oil drip on it.  So I pulled the plugs on both reservoirs, drained the oil and cleaned up the areas again with 320 grit.  Then I cleaned up the reservoirs to make it easy to spot a leak.  Tomorrow there's  porsche breakfast meet and the weather should be good, so I'll take the car there and then check it out again on the rack once I've gotten home.
docwyte
docwyte UltimaDork
3/25/25 10:18 a.m.
Borrowed my friends snow wheel/tire combo and drove this for a week or so until my Cayenne turbo arrived.  That was fun but also revealing, in that the spring rates on the coilovers 700lb front, 900 lb rear, are pretty punishing on anything but the best roads.  I live in Denver, we don't have very many of the "best roads".
I called Tarret and asked them about it, the rates I have are very track oriented and at the top of the range of what the shocks/struts can handle.  They recommended 500 front and 700 rear but asked me to check my front springs, as they might not be long enough to just be moved to the rear of the car.
I've got a bunch of coil over springs in my basement, but of course I have everything but 500/700's.  The closest I have are 400/600.  I've also got a set of 550's, so if I can move the current 700's to the rear, that would be close to what Tarret recommends.  I checked the spring rates of the Bilstein PSS9's I had before and they were 250 front and 515 rear.
When I talked to Tarret about running the 400/600 I have now they said it'd be fine, that those were on the lower end of what the shocks/struts were meant for.  I've already got them and they're still quite a bit higher spring rates than the PSS9's I ran before, so I'm inclined to install them and see how they feel. The PSS9's rode nicely around town and did fine on the track, so with these rates the car should still do better on track and hopefully be much more pleasant around town
rjk370z
rjk370z New Reader
3/29/25 10:03 p.m.
I just wanted to chime in here and tell you how impressive your build is. I just went through all 30 pages, in a few days. And I really like your progress. From daily, autox and tracking the car. My favorite part fo your build is you drive your car around and to the track. I see so many guys trailer their Porsche to the track. And you drive it to and from with the trailer. Major props. Thanks for keep up all us informed and entertained. I look forward to seeing more of your progress.
docwyte
docwyte UltimaDork
3/30/25 9:55 a.m.
In reply to rjk370z :
Thanks!  Driving it with the tire trailer gets a lot of stares!  Even at the track, people are pretty surprised when I pull in....
docwyte
docwyte UltimaDork
3/31/25 10:04 a.m.
Had a chance to put the car on the lift yesterday to pull my friends winter wheel setup off and I took a peek at the springs while I was there.
Front springs are 5" long and are 560lb/in.  Rear springs are 7" long and are 784lb/in.  So these are lower spring rates than I thought and are fairly close to what Tarrett recommended of 500/700.  I can't move the front springs to the rear, they're too short.  Since I want to put in the 400/600lb 6" springs I've already got, that means my alignment and corner balance will be all messed up, since I'll have to move all 4 spring perches.
Sigh.  I really don't want to pay for another alignment/corner balance.  This might turn into an off season job I do next winter...
docwyte
docwyte UltimaDork
4/4/25 10:35 a.m.
Friend had an OEM transmission mount with the Cantrell Motorsports urethane bushings already installed in it.  Grabbed it from him for basically the price of the bushings themselves.  This will make the install super easy and if I don't like it I can swap back to stock.
docwyte
docwyte UltimaDork
4/8/25 9:53 a.m.
Went and installed the Cantrell mount today.  This was a fiddly job because Porsche put two coolant hoses right where access to two bolts were.  When I finally got the stock mount out I saw that the bushings were beginning to crack.  Hard to capture on camera tho
Getting the new mount lined up was a PITA!  It's impossible to see up there and the mount can move in all axises, so it took me awhile.  I finally was able to line one bolt up and thankfully that lined up the other side too.
A quick drive around the neighborhood showed no increase in NVH (win!) and maybe an easier, smoother shift into 3rd gear.  I'll know more when I drive it more.
I still want to swap out the springs on the coilovers, just not happy about the thought of having to redo the alignment and corner balance.  Plus if I'll pulling it all apart and paying for that, I really should send the front struts back to MCS to have them serviced.  I'm really thinking this will be a winter project...
docwyte
docwyte UltimaDork
4/9/25 9:40 a.m.
Had to drop the DD Cayenne Turbo off at the dealer, so this Turbo is pressed into daily duty.  Drove my son to soccer practice last night and drove to the office this morning.  Vibration hasn't really increased, but the noise definitely has with the new transmission bushings.  The exhaust sounds different now and there's more gear whine transmitted into the cabin from the Numeric shift cables compared to before.  The shift quality has markedly changed for the better now though.  So far a win, but for a car that's truly daily driven I'm not sure this would be ok.
28 29 30
3JjJJxlGD3Kqfz0rx7o2lcXyvOR7qzuLBuAkY6ZSSuXBo6khP4a2L4x8TllUIi3u
