13 14 15
MiniDave
MiniDave Dork
2/25/25 5:12 p.m.
I share your feelings about the mess that some pads leave....my MINI factory pads were horrible, you couldn't drive around the block without them turning black!
But when I switched to some fairly high end ceramic pads, within 5K miles I had brake pulsation in front. Never had it with the factory pads.....
TurnerX19
TurnerX19 PowerDork
2/25/25 5:41 p.m.
Good semi-metalic pad material has run into the CARB. See what is available in Australia or NZ and import them.
Tony Sestito
Tony Sestito UltimaDork
2/25/25 6:07 p.m.
In reply to TurnerX19 :
This is a point that I had never thought of. Makes a lot of sense.
Thinking about it, if everything is going to leave deposits when it gets overheated, there may be a reason to do that National Mod after all. Bigger rotors and more caliper pistons will, in theory, make it easier for the car to stop with less effort. And I'm definitely getting deposits and overheating/glazing (see previous posts in this thread). Bigger brakes that work with less effort might negate the whole pad material conversation a bit.
FSP_ZX2
FSP_ZX2 SuperDork
2/26/25 11:02 a.m.
I ran Z23s on the fronts '17 Elantra Sport after I cooked the stock brakes at Road America.  I had the on the car when I traded it in--felt like they were decent for the money...certainly braked as well as stock.  I don't think that they were overly dusty either.
If I need brakes on the GT, based on what I'm seeing, they would be my go to.
Tony Sestito
2/27/25 9:55 a.m.
I decided to actually LOOK at the rotors yesterday to see if I could see any weirdness. And yeah...
Running a finger over the surface, and it feels a little lumpy on all of them. The top two shots are the fronts, and you can see the spots on them clearly. They look overheated in person, too. When I swap the wheels, I will either get these cut or just flap disc the deposits off and see if it helps. I may still do the big brake mod, but if I could hold off on that, it would be preferable.
The dumb thing is, this car has pretty large front rotors at 12+". It only weighs 2900lbs. When it was new, I was actually impressed by how well they worked, but it hasn't felt the same in years.
Now, riddle me this: My Power Wagon weighs almost 5000lbs and stops fine with rear drums and 10" front discs. My old Mazda3 had 11" front brakes and stopped fine as well. I was running el cheapo Max Brakes drilled/slotted rotors and carbon ceramic pads on that most of its life. It's braking system is VERY similar to the Kia but with smaller rotors.
I don't understand why the Kia can't just work. On paper, it should be great! Why the pads keep leaving enough deposits to throw things out of balance is an annoying mystery.
spandak
spandak Dork
2/27/25 3:55 p.m.
Would adding cooling help this issue? I'm guessing it's not an over heating issue but if cooling would help I would slap some Boxster air deflectors on the control arms and see what happens.
I put Bosch blue ceramics on the back of my Subaru and have been really impressed. Just another budget option.
Tony Sestito
2/28/25 8:58 a.m.
In reply to spandak :
Maybe, but I'm not sure. It might just be a "brake pads just suck now" issue. My wife's CX-50 has a slight pulsation coming down from highway speed too, although it's not as pronounced or consistent as my car. I used Dynamic Friction pads and rotors on that one too. And yup... deposits all over the rotors.
I know it sounds dumb, but I never had deposit issues with the Max Brakes slotted and drilled rotors I used on my Mazda3 for years. I only used those on the car because they were dirt cheap at the time, but they ended up being really decent brakes. They never had the cheap slotted/drilled cracking issues that you always read about. Maybe the slots helped keep the pads from leaving deposits? They don't have a set that fits my car, but Power Stop does make one, and I'd be willing to bet they are the same thing.
Tony Sestito
3/18/25 12:01 p.m.
I have a 65k service (aka an oil change and look at fluids) to do in the next couple weeks. I'm planning on making the summer wheels switch at that time and taking a look at the brakes, my favorite activity! I plan on at least hitting all the rotors with a flap disc or similar and seeing if that helps the vibration/chatter issue since the rotors are pocked with deposits.
That said, I am 99% sure that I've made up my mind about doing the National Brake upgrade. I asked in a FB group if anyone else did it, and aside from the usual responses telling me to dump $600+ on EBC pads and multi-piece slotted rotors, a few people chimed in and said that they had the same exact issues I was having and doing the mod solved them. I priced it out, and I can get new Mando (aka factory OEM) calipers, decent blank rotors, and SEMI-METALLIC pads for around $250. That sounds like a bargain to me. The fact that they make a semi-metallic pad in that size is also appealing, and those pads are dirt cheap to boot compared to what's available for the stock brakes.
One guy sent me these pics to show just how much larger they are than the stockers:
That's quite the difference! The thing I don't get is why they didn't just do this to begin with. These cars have larger brakes than the regular Forte already. They spent time developing all sorts of GT-specific parts, like the stainless exhaust, multi-link rear suspension in place of the beam axle, and more. Why didn't they just bolt these on if they were going to go larger anyway? I don't get it at all.
Tony Sestito
4/5/25 1:34 p.m.
Yesterday, I did my 65k service, which meant I did an oil change and looked at things under the hood; all good there. Engine is doing great, and not burning oil, leaking things, etc.
I also changed out the winter wheels for my "3 season" wheels. While I was there, I decided to take a look at the brakes again, because the shaking under braking has become unbearable. Were the rear calipers frozen again?
YOU BET!!!
I'm not sure how many times this has happened now, but one of the rear calipers had the slides freeze up. This time, the grease didn't solidify, thanks to my use of synthetic slide grease last time I had everything apart. So, what happened now?
This is the passenger side rear caliper bracket and its pins. Two things happened:
-One of the pin boots swelled up to the point where it was letting air in and "air locking" the pin from movement
-The pin on the left with the rubber grommet on the pin had the rubber swell up and lock the pin in place
Very strange.
In all my years, I haven't had a pin boot swell up before. I talked to my mechanic nephew about it, and he said he's seen this a lot lately, and he thinks it's due to the slide grease. The newer formulations of this stuff don't like rubber apparently, and they make it soften and swell after a while. His dealer uses a special product that is more of a mineral lube than a grease and not the same as the parts store stuff. They haven't seen any issues since they switched over.
The strange thing is, the other side is fine, as are the fronts. It's just this one was the lucky winner. At least this time, it froze up open. Some new boots and one new pin (the one with the rubber) and things were moving freely again.
But because it froze again, it glazed and overheated the front rotors even worse than they already were. These were pretty bad:
These rotors have about 5k miles on them. Plenty of thickness left, but tons of deposits and hot spots. They don't feel warped by the touch, but they were cooked. I figured I could just get them cut at the local O'Reilly and call them good, just to get a fresh surface on them.
WRONG AGAIN!
Despite every store having one, none of the O'Reilly stores in my area know how to use the rotor lathe. "Just buy new rotors" was the answer I got. Yeah, thanks, Captain Obvious. No other shops/stores in the area bother with those either, so I decided on hitting them with my Death Wheel Brush Thingy and tossing them on. That at least knocked the deposits off, and seemed to make things at least a little better.
Braking is improved, and all of the calipers are working now, but it is still not great. They still shake a bit stopping from higher speeds, and generally feel terrible. I am hoping it self-corrects, but I don't have my hopes up.
At this point, I think I'll get the "National" brake mod bits, all new boots and pins for the rears, and that fancy slide lube and hope that the 6th time is the charm.
Tony Sestito
4/7/25 10:04 a.m.
After doing some research, I feel like a big dummy.
Yup, that brake grease I used 100% swells up seals. Specifically, I used this:
This is EXACTLY what's going on and likely causing all my current problems. At first, it was catalyzed, hardened grease in the slides from the factory, but now I've compounded the issue with a new problem. So yeah, despite what the bottle says, DO NOT use this on the caliper pins. It is, however, good for the pad ears, and I'll continue to use it for that.
I ordered up all new seals for the calipers front and rear, and a bottle of this stuff:
This is a silicone-based lubricant, and it doesn't hurt rubber. Lesson learned.
Tony Sestito
4/10/25 9:18 a.m.
The saga continues.
Yesterday after work, I got to work pulling everything apart, cleaning, lubing, and checking everything.
Armed with a can of Syl-Glide, I got to work.
I pulled apart every caliper again, cleaned all of the synthetic CRC grease off of everything, clearanced the pad ears (I did this when I installed them last year, but they got crusty because New England), lubed the pins, lubed the brake pad slides, replaced all the rubber boots and pin grommets, and made absolutely sure everything moved as it should when I bolted it back together. Turns out that the front calipers were also not moving (no surprise there) and the ones I took apart last weekend were already freezing up due to that stupid grease.
The result: I now have four working calipers that don't hang up. Yay! The car still shakes pretty bad coming down from highway speeds, but the overall lumpiness around town has vastly improved. It also doesn't feel like the car is being held back like a dog on a leash now, you know, since the calipers aren't freezing up. Plan is to just drive it as-is for a while until I get annoyed enough to do the National Mod and do the brakes again. I'm hoping the shaking goes down over time since the brakes are doing brake things properly. It does stop much, much better now.
Moral of the story: NEVER use anything but Syl-Glide or an equivalent silicone-based grease on moving brake parts.
TurnerX19
TurnerX19 PowerDork
4/10/25 11:19 a.m.
In reply to Tony Sestito :
The awful part of what you just said is that there are many old compound rubber parts that are not compatable with Sylglyde or any other silicone.  Rubber chemistry has two basic types that are used interchangeably in some applications damn it. Both types are compatable with conventional brake fluid, only one is with silicone fluid. Both OK with water, only nytrophylic base is OK with mineral oils. This proves as well that the CRC is not 100% synthetic, and the original seals were a cheap shot, because nytrophylic rubber is currently more expensive from the base line. This is related to the deteriorating window seals as well, UV resistance is expensive.
Tony Sestito
4/10/25 11:29 a.m.
Interesting. Well, on this car, it's definitely getting Syl-Glide from here on out. Apparently, whatever rubber they used here doesn't like the CRC stuff, but SHOULD like this. In the past, I've also used good ol' Permatex Anti-Seize, but I don't dare try that here, since it has those pin grommets, and the Anti-Seize is just too thick. Most newer stuff has the same type of rubber boots/grommets, but older cars might not like it.
Tony Sestito
4/24/25 11:07 a.m.
A couple weeks later, and the car seems to be sorta figuring things out. The brakes are no longer hanging up, and the tire shake on the highway is still there but seems to be improving. Shuddering under braking is also still present but getting better. Gas mileage is also improving as well, which is a good sign that the brakes aren't hanging up anymore. Really dumb how something as trivial as the wrong grease could pretty much ruin a car, but here we are.
13 14 15
kByVwrRNneuZJgaKytGZm5EIPBgrl0KOgtDcwnBrCc0Tq3iSwZSc9DZz0bTcNs4H
