wheelsmithy
wheelsmithy SuperDork
12/31/19 11:59 a.m.
Call Art Morrison.
TurboFocus
TurboFocus Reader
12/31/19 12:38 p.m.
In reply to wheelsmithy :
That would be sick but that frame looks like it costs 10k...
I'm on like a 1k budget for a back half
Patrick
Patrick MegaDork
12/31/19 12:43 p.m.
How experienced are you with a welder?
you can get the competition engineering ladder bar frame rail kit and front crossmember for under 500, you already have ladder bars and 9".
AnthonyGS
AnthonyGS Dork
12/31/19 1:09 p.m.
Buy welder, practice lots, then get after it....  that's my current plan.
TurboFocus
TurboFocus Reader
12/31/19 1:27 p.m.
In reply to Patrick :
booger welder, but it usually sticks together. I'd either get my buddy to weld it or pay someone to weld it. I'll stick to welding smaller, non-life-threatening stuff.
Images are being uploaded to imgur right now, Ill post a half a dozen sexy pics and half a dozen of the worst rust. Links to all the photos will be available. Some of the sexy pics are on IG right now, I'm actually updating the forum post faster than I usually would. I don't know if it'll stay that way but for now y'all are getting the best detailed info.
TurboFocus
TurboFocus Reader
12/31/19 1:55 p.m.
I guess we'll start with where the rust is and if I've found replacement panels for it.
The trunk area, I'm not sure what all these panels are called and other than the trunk lid itself, I haven't found sheet metal replacements.
  • Just under the window is a ton of holes and if it's possible I would just replace the whole thing - ???
  • The area  where the window rubber gasket is has a ton of surface rust that i'd likely just sand away, re seal and send it. Again, if I can just get a whole new edging without being forced to buy new quarters, roof, etc I'd do it. However that doesn't appear to be the case so we'll wait and see on that one. Not a huge deal I dont think - ???
  • Around the edging of the trunk are tons of rust holes, again, I think this is  going to require new panels everywhere. I really dont want to do that... - ???
  • Trunk floor has holes in it as well. This one im not actually worried about at all. I'll likely just do 50x small patches and throw carpet over it - fixable but maybe not worth it
  • Trunk lid has a hole, looks easy to patch and the rest looks reasonably clean - fixable
  • Prev owner cut holes in the floor as well as did mother nature with her rust. Also not worried, patch, paint and carpet - fixable
  • Doors and rockers are pretty much shot all around imho. I might be able to get away with skins but I dont know if its worth it - Replacements available
  • The actual body of the car has numerous small holes, none of it looks impossible but it does look like a PITA - fixable
  • BOTH rear frame rails are completely rotted away. I'm sure some one makes replacements of these but I haven't found them - probably fixable???
Whoever makes that weld through paint/primer stuff is gonna make a fortune off of me should I actually pursue fixing this car.... This is also all I found without jacking the car up into the air.
There are tons of little broken things in the car as well. T-top handle is broken on one side and  doesn't properly latch on the other, door isn't very aligned at all on the driver side. None of this stuff scares me but just adds to the amount of work involved. If there wasn't such a sheet metal demand I wouldn't even be questioning this cars restorability with my skills and budget.
Thoughts? WWGRMD?
Sexy pictures - Proof its pretty clean firewall forward - Rusty pictures
Dusterbd13-michael
Dusterbd13-michael MegaDork
12/31/19 2:09 p.m.
iansane said:
NOHOME said:
I would go looking for a C5 and skin it down to the firewall and drop that TransAm shell over the top. Yes there is a matter of a 4" wheel base mismatch the TA being 108" and the Ct 104.5"
I like this idea. And 4" gives you a good amount of frame to stretch to fix drive position/dash/steering wheel inconsistencies. Although then it's either stretch the the torque tube or set the engine back a bit...
Or radius tbe wheelwells for clearance, leaving the c5 stuff alone.
Crackers
Crackers Dork
12/31/19 2:46 p.m.
IDK if Classic Ind is still around, but you used to be able to buy a whole 2nd gen in parts.
I'm almost positive I could back half a car and 4-link it for less than $500. $700 tops. (Not including paint) YMMV
TurboFocus
TurboFocus Reader
12/31/19 2:55 p.m.
In reply to Crackers :
Yea, I saw frame kits for 500-600 bucks. That looks like the way to go. Cheaper than another 2nd gen, makes it drivable, doesn't toss the entire car.
Only thing I'm iffy about would be cutting all that out, would the body want to twist and bend? What's the best way to go about it?
Again 0 research in, but I got other stuff I need to take care of right now
Patrick
Patrick MegaDork
12/31/19 3:02 p.m.
berkeley the body rust, tub it and send it
NOHOME MegaDork
12/31/19 3:03 p.m.
If you want to back-half the car in the driveway, shim the axle stands so that there is no twist to the car. As long as the car is supported on a single plane it wont twist and you should be able to use triangulation and existing chassis datum points to locate the new back-half. Use plywood under axle stands or screw-jacks to achieve a single plane support.
Do some cross-measuring from a back panel or crossmember that is going to stay to some points on the axle and that way you can be sure the axle is in at right angles in the right place when you are done.
TurboFocus
TurboFocus Reader
12/31/19 3:53 p.m.
LOL, I would like to not look at my dream car with holes in it. Dents, scrapes, runs in paint all ok
The size of those holes? Not so much.
However, it might be sent to get it going and then fixed later
TurboFocus
TurboFocus Reader
12/31/19 4:00 p.m.
Put it in the air, (four jack stands) make the car level (shim stands with wood, sheet metal ect), install everything level, measure to make sure its straight. Stitch it together for good?
How long would this take a couple dudes doing it for the first time?
Difficulty level?
Patrick
Patrick MegaDork
12/31/19 4:18 p.m.
Upon closer inspection I would part it out and chalk it up to a learning experience.  There's lots of rot in areas that will take more time and money to fix than acquiring a clean shell
Datsun310Guy
Datsun310Guy UltimaDork
12/31/19 5:02 p.m.
Put it back together with all the parts you have and park it in the garage.
When friends or guests come over make them sit in it and drink a few beers and relish long about how your going to fix it up since it's your dream car and drive it all over the country, maybe even race it.
Then head to your patio and grill out some steaks but don't ever do anything to the car.   You can do the same with a boat in your driveway.
Cotton
Cotton PowerDork
12/31/19 5:02 p.m.
I love it,  well done!
AnthonyGS
AnthonyGS Dork
12/31/19 6:17 p.m.
I'm a native Texan.  I don't do rusty.  I will drive to NM or AZ to buy a car free of the stuff if I have to.
I had a friend save a rusty 71 Mustang that I wouldn't touch.  It can be done.
It's a labor of love though.  If you do it, you get a free to wear a mullet for life pass.
NOT A TA
NOT A TA SuperDork
12/31/19 6:27 p.m.
That's a parts car. Don't waste any time on it until you find an appropriate car to swap some of the parts to. I wouldn't take it apart or anything, just cover it up till you find a better body/chassis to start with. At least get a better unibody.
TurboFocus
TurboFocus Reader
12/31/19 7:36 p.m.
well guys, locating all the stuff I need to complete the car is a complete PITA
while not impossible nor bank breaking yet, I found a base model 81 not far from me for $800. im pretty sure the door skins were 80 a pop, rockers were similar a pop, a rear subframe kit was 300 for a pair... I'm already at $620 plus the time to install it AND i have all those other parts to patch and fix.
I messaged the guy to check it out, If the doors, rockers and rear subframe are all in passable condition... swapparoo might be the final answer.
I could part out the left overs since I'll want my own carpet/interior
AnthonyGS
AnthonyGS Dork
12/31/19 9:22 p.m.
If you have the space finding a rust free tub is going to be a much easier project.  Go for it!
Tony Sestito
Tony Sestito PowerDork
12/31/19 10:14 p.m.
While they do make just about everything for the late 2nd Gen cars now, I'd focus on finding a cheap non-T/A roller and build that, especially since you don't care about provenance. It would be far cheaper in the long run. Regular 1977-81 Firebirds are still out there in your budget. Keep in mind that the tail panels are different on the 79-81 models due to the full width tail lights. Other than that, it's all the same stuff underneath.
NOT A TA
NOT A TA SuperDork
12/31/19 10:20 p.m.
This ^^^ is by far the way to go. There's nothing special about a TA unibody vs. a base or Esprit body. I've swapped the front half of a 78 TA to the unibody of an 80 Formula and many other 2nd gen projects. I've been working on 2nd gens since they were new cars and we were doing day 2 mods so I can probably answer almost any question you might have and if I can't I know someone who can. Looking forward to watching this project!
Oh ya, there's only one sub frame in a stock 2nd gen and it's in the front. There's no "subframe" in the rear. The rear rails are welded to (and part of) the unibody.
NOHOME MegaDork
12/31/19 10:36 p.m.
In reply to TurboFocus :
That would be an elleventeen on the "holy E36 M3" repair scale.
I did one that was that bad, took ten years. Came out really nice. Maybe 20k not counting tools required.
Very big learning curve and sense of achievement.
Won't do another  like it on my dime.
Pete
Agent98
Agent98 Reader
12/31/19 10:38 p.m.
X2 on the swap parts to a rust free tub idea. There's always twice the rust lurking that you don't yet see....
TurboFocus
TurboFocus Reader
1/1/20 6:43 a.m.
If it's still available at next paycheck, its mine. My job owes me a chunk of change that should be getting paid out soon.
I do have a couple questions, first has to do with T-tops. How hard is the swap from a donor car?
The second is a little more complex.... I'm going to be keeping the T/A dash vs the base dash. Is the vin attached to the dash? I don't like the idea of popping it out nor do I like the idea of a mis-matched vin on the body and dash. WWGRMD? Make it obvious that it's been tampered with and register an 81? Swap the hidden vin from the TA and register as a 78? Or am I crazy and the dash comes off around the vin?
Halp!
cNONejTNBu9rLUkvcRHj90di8IJZHFrbJUeSc8Xn1vgnEBDOc1vjqja4mUBILMni
