This weekend started off with a huge snowstorm, which apparently caused Tractor Supply to not have any shielding gas refills- since it was the third time that they have been out when I needed some, I traded in my TSC tank to a nearby welding supplier instead and will be using them from now on, since it's worth it for me to drive slightly further to actually get my tank refilled instead of the "convenience" of TSC.
With freshly refilled gas, I fired up the welder to get my subframe modified for the Supra diff. First, I loosely assembled and lined everything up:
I needed to grind a little bit for clearance on one side:
Then I snugged everything up, rechecked the alignment, and tacked the nuts into the brackets- then took it all apart to weld the nuts on:
Bolted the brackets back onto the diff, got things lined up again (the sheet metal I designed lines up with the factory bolt holes for positioning, although it doesn't use them) and measured one more time. Then tacked the brackets on:
And removed the diff so that I could weld the brackets, as well as the box sections to close them out. Hopefully this is beefy enough:
The rear mount and its' corresponding pieces on the unibody will wait a little bit, since I'm going to want to have the engine and trans installed to check pinion angle.
Since I'll be welding stuff to the car near the gas tank, but want it installed to check clearance, I installed the new filler neck grommet in order to fix the small fuel leak there. It should also help me avoid having my car blow up when Josh flicks cigarette butts at it in the service park. The offending grommet:
The new one looks a bit better:
With that done, I moved to the front of the car, wheeled the complete engine, transmission, and subframe under, and lowered the lift:
I've never had the pleasure of installing an engine using a lift before, but the summary is basically scoot, then lower, then scoot, then lower, then... repeat many times until you're here:
That was... surprisingly easy! Having a lift is the best, if you have a $3k car sell it, buy a $2k lift and a $1k car, and I bet you'll still spend less time working on it. I ran the subframe bolts in, and then hit the big green button:
And bolted the transmission crossmember back on:
Sara and I then reconnected the steering, clutch, and oil lines, and decided that would be a good place to call it a day since it has no oil (I need to order more!), needs a bunch of new plumbing, and if I go down the engine bay assembly rabbit hole I won't stop until midnight. I'm going to try and channel my inner Mazdeuce and stare at this throughout the week so that I can hopefully do brilliant things with the plumbing/wiring/etc rather than my usual technique of slamming it together and calling it good enough:
