I haven't had a chance to tear the salvage motor down yet, but there are some other things piling up that need doing on the FD and thought I'd post an update.
First, I mentioned I'd pulled the trigger on a downpipe, in an attempt to reduce the underhood heating. It's from Pettit Racing, and I'll be adding a second O2 sensor bung and installing a wideband to keep tabs on things. If it looks too lean I'll put the stock downpipe back in.
Second, it looks like the Ohlins have a bit too much travel up front. A couple times on mountain roads I've felt a front tire rub under compression with a certain amount of steering lock. Then I noticed this -- it looks like one of those times the tre caught the fender lip and bent it outwards a bit:
My first thought was to take a fender roller to it and see if I could bend it back gently, but I was talked out it. Instead I'm going to let the body shop guy look at it. The long-term fix is to add one or two of these to the shock shaft to limit the travel:
(one of those packs is for the Xidas on the Miata, the other is for the FD. I forget which is which, they're different sizes)
Another item that's come up is the front fender vent. Often I would go for a drive, come back and notice that the passenger side one had popped out a bit.
I'd pop it back in and go on, and then it would happen again a couple weeks later. Well, last week it came all the way off.
I've got the vent piece, it didn't actually fall to the ground but was just barely still wedged in place.
The paint on it is fine, but the plastic clips that hold it in are well and truly broken. Fortunately, Mazda still makes them, so I orderd a replacement.
Obviously it needs paint, so I'll coordinate this and the bent fender with the body guy at the same time.
