Pawpawnati
Pawpawnati New Reader
4/6/24 12:55 p.m.
I purchased the not running last summer, spent a bit of time working out some of the issues to get it running before the PNW rains came for the fall. Since for the first time i found myself with a reasonable organized shop,  full of tools of my own and TIME. I decided to go my way and build somethings a bit more creative but with purpose outside of the whole "037" "tribute" business or a "show car".  Built to break and rebuild.  This means eventually ill make molds/reproduce as much as possible from glass/carbon to preserve the pricey bits of a car that may only be 1/500ish still on the road stateside.
Ill photodump, and get around to more descriptive breakdown posts.
TurboFource
TurboFource Dork
4/6/24 4:05 p.m.
looking forward to photo dump!
chandler
chandler MegaDork
4/6/24 7:00 p.m.
Ditto
Pawpawnati
4/6/24 7:37 p.m.
Pawpawnati
4/6/24 10:33 p.m.
etifosi
etifosi SuperDork
4/7/24 4:04 a.m.
Pawpawnati
4/9/24 9:50 a.m.
I began testing electrical function last night, and it seems to all be working with my modifications. I spent a lot of time to maintain the same circuit colors as reflected in the stock diagram. Engine piping should be next, along with the facet fuel pump, brake lines, and pedals.
Slow_M
Slow_M Reader
4/10/24 3:27 a.m.
Any skid plates?
Are you going to modify front and rear valance / bumper?
What shocks?
Love those wheels! Ronal Turbo?
Pawpawnati
4/11/24 9:32 a.m.
In reply to Slow_M :
Skids 100%, bumpers probably not, just remove em for the race.
i picked up some Vicks auto coil overs, and plan to replace the small helper spring that does nothing with a soft 2-3" 150-185 or so. Sorta a bootleg setup but it's not pricey and the quality seems good.
brad131a4 (Forum Supporter)
brad131a4 (Forum Supporter) Reader
4/14/24 4:44 p.m.
You actually have a set of Ronal Turbos with a 4x98 bolt pattern. I'm impressed. Not to sure about the rally cross aspect of the build but it's your car so have at it.
cheese
cheese New Reader
4/14/24 4:47 p.m.
Beautiful car and project, definitely following this one. I think you're a little nuts for racing such a rare chassis in good shape, but at least molding new panels for racing to preserve the original sheet metal is a good plan.
Lof8 - Andy
Lof8 - Andy UltraDork
4/14/24 4:58 p.m.
Siiiick!
racerboy000
racerboy000 Reader
4/14/24 5:28 p.m.
Yes!  So much yes!
Pawpawnati
4/17/24 1:15 p.m.
In reply to cheese :
A little nuts, what a compliment! :)
Hoondavan
Hoondavan Dork
4/17/24 1:34 p.m.
This is awesome.  Please continue.
rozap
rozap New Reader
4/17/24 2:50 p.m.
This rules. I have dreams of turning my X1/9 parts car into a rallycross car in a few years.
etifosi
etifosi SuperDork
4/17/24 3:30 p.m.
Pawpawnati
4/18/24 11:23 a.m.
with the wiring complete minus the tail lights I took a break to get the lexan I had laying around the shop cut and fit into the spare "race" doors and rear. I'm keeping the roll up glass setup in the other door cards intact for street use. Same thing goes with the rear glass, think preservation and also a bit of weight savings. The unfortunate matter is that the windshield had to be reinstalled despite it having a 6" crack.
Pawpawnati
4/20/24 11:03 a.m.
With the sheet metal out, it was time to start on the first phase of cooling improvements. These cars are prone to engine and engine bay heat. Hence why the 037 has some big ole scoopy do-dads on the rear triangle. I don't generally take this many process pictures but i did. hopefully they are helpful if not at least pornogaphic to someone other than me.
Pawpawnati
6/22/24 1:00 p.m.
It's been a moment, my wife and I run a vegetable farm so with the summer coming in I've neglected much of my online presence. Anyways. Still working away on the lancia for my race in about a month. Here is how it's sitting.
daytonaer
daytonaer HalfDork
6/22/24 3:02 p.m.
Love the car. Can you share your garage setup specifically the pit? Did you DIY the pit, do you have ventilation, do you have any problems with water?
TurnerX19
TurnerX19 UberDork
6/22/24 4:52 p.m.
Please try to cover your timing belt. The factory cover is not enough to keep stones out of the belt, and I do not see it. I'm jealous of the Ronals too.
Pawpawnati
6/28/24 10:16 a.m.
In reply to TurnerX19 :
Without a doubt. I'm also planning to work out some form of smoothing/Skid plate in the rear to limit the places things could get kicked up in there.
BA5
BA5 HalfDork
6/28/24 11:10 a.m.
I love twin cam engines with the cams in separate housings.  I always think that looks so cool.
Pawpawnati
3/28/25 12:04 p.m.
Things continue to improve on my trevi VX swapped Scorpion. Here are a few pictures from along the way. “Not pictures: all the people that helped me figure this out and encourage the process”
-After the initial motor rebuild the charger showed signs of a bad seal which required me to fully dismantlental the supercharger. I send out to a cutting milling service my cad design and it worked super well. I was able to work out the “circles” of the charger for a nice fit along the outer most points of the lobes.
-I took this setback to also include turning some guide rails for the drive belt cog, and improving the tensioning bearing bracket to accpet a more available part.
-This transmissions ratios are SO MUCH BETTER than the stock gear box. I was able to figure out how to swap linages without opening the case (measure twice, cut, file, machine etc)
-With the DCNF 40, modifying my Venturi (yes, with an old regulator as the raw lathe material… lol)  to 28mm from 32mm improved throttle response by a mile, as well as keeping my AFR within a happy margin. (Further jetting, or just wait to get a fox injection type setup tbd)
-ive admired idf swaps to retain “stock look” but i feel better about the setup now as im able to draw cooler more favorable air from outside. Better ducting some day is a goal!
Currently working on getting an additional motor mount to play nice with my exhaust driven distributor and determining if I need an improved fuel delivery.
Birthdays
yNFDJ2KPcvPMNPuVJ0lThOhR7gwwJsP4H74dOPWhhu8afPH7QATKVfIZZDuYTCgA
