Tonight's update brought to you by...
Since I haven't been able to make a parts order, I've been after other nagging things that I simply haven't wanted to do.
The roof of the car had worked itself free from the interior "cross brace" the factory installed. It was glued in place, and the glue failed. So to keep the roof from acting like a steel drum when it's driven, I welded the two items together. (Camera is on the floor of the car pointed up)
Then after hours of cleaning, removing ever more of the heinous carpet glue, scuffing and cleaning again, the floors are painted. Two coats of gloss white Rustoleum. White was definitely the right color to go with, it is so very pleasing to look in there now.
I didn't paint the bottom of the spare tire well because there is a rust hole I need to repair first (hardly a surprise at this point)
There is so much room in there! This view ^^^^ in particular always brings the following scene into my head...
Three cans of Rustoleum undercoating were sprayed on the underside of the floors. I didn't take a picture because they look the same, but now they are black instead of gray.
The front bumper was removed, and rust was addressed on the front "valence". Luckily none of it had eaten through, so no repairs were needed. But I ended up sanding the whole area, then stripping the paint to make sure all the rusty stuff was exposed.
Made sure it was as clean as I could make it, then primed it with a can of paint from our sponsor.
And that coat will dry for a while until I decide which can of Rustoleum to use on it next. Quite possibly a layer of the undercoating I used on the floors, as the label says that stuff can be painted over. So it could then be painted the same color as the rest of the body.
In the meantime I've started considering final colors for the body. The original paint (I believe) is called Frost Blue, and Rustoleum does not make a color close enough to fake it that I have found. Neither do the other paint makers in this market segment. Internet.com searching shows there are some paint codes out there to match it from PPG and someone else. It seems to me that it would look very nice in white, but a complete color change would require far more effort than I have to offer. More to think about I guess!
