Well, the big contest is on October 5th and her application is in.
Now it's time to finish up all the quirks and get this thing working reliably.
After I installed the new motor, the pulleys were no longer aligned so I had to move the bottom pulley out. Instead of changing it's design, I drilled and tapped holes in 3 m10 bolts to use like leveling legs on a dishwasher.
![](https://lh3.googleusercontent.com/3xQsp7Rtu_3qIbpN30NXzKpPx6wJNzZBWvkgu7TyBaze8vh9wn0Xqb8NuAfu4TFR7tRoubZJ1Ju9fDIoWroK-UuXMBa91aJGPpTTYCASTpdAuzqM1XxLpGajK7Zfvi2Fsm78tmQXHMUgOWAj4OB8c4dF5_WvDJff2D_C25svnNso3LeJwgYGD_ogU9byk-EoC8cRPcGNxlf0Y0Fo-7rscD4qvaLBRU_H4lymPBTLL0Xlw51czkMqZbhjFrm8d6xitdBNXe1gk-hfRuj3HnDXMeCfueBqiHGO9a2-cmVvXK1fVZLz9rizNjWJ-r49uOZAHFlDUJRpHPSHYP4kaS6v7H4Cep5y06OBZLkbN44CE3dzVgncj67FNrKNGmpHTdOwEUuOuwj31W7enwHt8KtEsacriSD8T3Mhtkgwn2UhHwUezF5JrnwhT_HsSBTmw4-Zxk4JZVb1K9-2jPyAaIwqwa7f4LcKzsCWST5uDq5QqJHw6Rd2mvd-4B7dQJqnCVuD42jquPT8urdSqHZjdd__rEl63cQ3nF4pqBoUI9J_zujSjr9DoTqmJU3QGQEczRMshdWDhWOL1J3aPf8E4B-z__VuRdb_QkY6ffMWHH2pqS7m8xHIX8zZcPtQKS-PR8gdyjT8toIwjqAkkUVoRrF5DDaZiLyrwy7qbTvWB21rKftGQuY-T1eTxV_w2HkHuFm6gwjqbq0Ir_Czuo-ng2FZTiyXWOaTgDx0r14GkjfPIUnpm7ik=w708-h944-no)
I also turned a new top pulley that is both larger and properly centered.
![](https://lh3.googleusercontent.com/P60TkQYZ2HbQKzzkQy3SBch6kWSKmcE2QoXvmbGNbqXBpGjmzpVBtbQBZ3dZ57gOGIkeBs5A3V0-ZmT7rjfaONcwEtSwffb4LQ_IfTC5H6KxNYuVbDCPnsk5p5PeG6E_27PVB4nhhsAF01UOASTdGgtbFni_q56hSwAEl8TlEOYuuO59wCmjJP_wKA6J3xb_BI6QnxM8GrJXdBEFmm6m8Gqj7k7OuJMcJ019wSH8NCxPn8QTb0vpj1Ah2qCEIlTgrVZfw1zovQwqDo-3dH48NxwWYgZ7dwo_iqHxj6lYa3gg7eXiLVKIAIghDqGiPp0FL1I3xyyJb-lVpzPmZR442LGikT1Cy2dFlTb_9DIcrw6ykG6OTR2qZrOdWbVA-C4AZtMimQlOib7cscT2mq3w4Rua2pGdNXiK_UTee0oU_PQ8g6AXVq195GHWSX3Sq-YeSl1K51zIjibjHSSBh5o_K9QYyTyH_og1d-8hVTfz8qccceYZJDSCoXWBGel70cf2sVvpz99pJ9YLGQ517a3KRF6jcoRYb0Pq35dC-oah5yK8ag1KZjkO_n8huCswmb9Zc34-7kdBBMZIiKjHSnfilJanGfItEvXkQifeWLuW7BVCF4TLWnoOxVtjzX9mTjeMLcn3SC9KrJqvppPt4BFMOMz1GCDgK1F-IgqgZ8YlpqD1Cwu4rQJ5W-ppKMuEL08OeY-rRamOoQwW-bsCSJ9_6cVSoRnGklTxS_ExLEj1wZEpwwZT=w1259-h944-no)
This got everything running much smoother and faster. However, as I mentioned before, the small battery i was using, would cut out under the larger motor's load.
I ordered a speed controller with a built in soft start. I wired it in just before the motor and tested it out. It worked! however, only in the up direction...
I assumed the problem was that you couldn't run the current backwards through the speed controller (It was wired in after the switch that changes the polarity)
So I cut the wires apart and wired the speed controller in before the switch, so that the power would go through the soft start first, then go to the switch to be sent to the motor either normal or reverse polarity.
That's when the weirdness starts... Now, it works in either direction, but only once. So, you can turn the battery on, flip the switch and the motor will run (either way). however, after it his the limit, or you stop it manually, when you try to run it again, the battery cuts out...
This happens if you try to run it one way, then the other, or if you try to run it the same way twice. For some reason, you can't run it a second time unless you reset the battery?
So I'm super confused and I have a second battery coming in this week, I will wire it in, in parallel, so that each battery should only use half the amps. I hope that that fixes it but I really want to know what is causing this weird issue?
Well, here is a kind of jerky demo of the improved speed of the wings that is sort of ruined by the fact that the belt is not tight enough. Making a new tensioner bolt is next on the agenda.
![](https://lh3.googleusercontent.com/8CcxLv9qTUxbBgnk0M0rsPJmXZuatmUhuICLvsJVWkVSDXYpbDjNqePnAkcTNFAvzhCqY1h0EpKh3vSfUGiM9UpTjQsINjRBsMMDKcDn9cM_NBsXLX9I6PoN2jQM-MYthfPUGTjQ3EKHtou609fWmtjr7LHut0lYkt8kuHvj17h-jn5Gx-SNOGLTIu8RG61mgNPxP9-YlgZetxsn-VqU1bIBqS0XzJ-9AE7TUrLPDlaiFM5ao0Haibs2Vl2NAmLDzVhshrUnNu7_8fyFgTCa7qco5ba-UhE9errQ6DZTPwadiXpGOwLc3k4aHnrCyUBhEOzcQzSSsg0e4lrtDL4LTJCFQny9x8qE-lat2g12BV3MO330__ovfVZAJiV4Jyhm7z_APFYXEs7cTWpsC2yWrASE4L1JwBNsWgZ606ItC6qkCVqncWmKqvWHHLfdhia6Dv2njvFnjA4dg5KtTekicpc_tFhrlAomIIxa1zKA9a3OzYLo-xrHeXkcUb4NUVQKXT7jilFH4328ZrFZlSwUoDRJ7cVOwfNQDxoL8tAtOdsbdyOduPs-Be4VQ6HMbQpuRicT4s95h92RpgxstEP2suEOxFNryMAx53Qhfy_tceYclY--Wqw1zLVGc0AwYwhYcl5CS701ofuK-446a2d2T9TBwvvbcCCnv9m6r1Ir68lrrqfA4vm1-sGWfDai6vM_OQ6otG3ejwbH3fx71khJMBfE_axZ7iq-S_xqP34cxO0Cm769=w480-h270-no)
